Should this be 90kW?we have a large roof and I've just had 9kW of solar panels fitted.
That rate is better than I could find here four or five years ago.A friend converted a barn years ago and had a full height lobby. He decided to put a bathroom fan near the apex of the roof ducted down to floor level. He said it wasn't worth the effort.
I had a look at the rates the other day and it was ~£0.09 economy 7 ...
Only if he lives in a railway station.Should this be 90kW?
Only if the stove is closed down too far. I go to open it up before my wife who is in the room knows to do it.i like that idea and have thought about doing it myself for years. Do you ever get the smell from the wood burner in the bathroom or the bedroom?….. in other words is there a risk of dragging in any fumes?
Could you link a couple of stoves with back boilers to a highly insulated tank. That way you can heat up water when you want it at night ready for a morning shower.If and when we move (much more "when" rather than "if", thank goodness), the new place is about double the habitable area of our current house and has oil because there is no gas in the village.
The current owners have removed all of the radiators and all but two rooms have wet underfloor heating. The other two rooms, both receptions, have wood burners. The house is a hybrid of cob, Victorian stone and block cavity - because it has been extended over the centuries. The current owner says that it's decently well insulated although one reception could do with dry lining (as it hasn't been modernised) and the one accessible roof space has insufficient insulation. The other is inaccessible and a bit more is vaulted - so I'm a bit stuck there. The whole house is double glazed with low E glass - somehow, the place escaped listing - which I am not complaining about! The garaging has 4Kw of solar but the inverter doesn't have battery. The FIT rate isn't magical, but it all helps.
We will have to see how the energy bills work out.
Each room has an individual thermostat so can be controlled pretty effectively, we think.
I have a PV dump system in this house whereby surplus solar energy, having been counted for export, is then routed to the immersion heater. It works well here aside from stratification which limits how much of the tank can be heated. The new tank is a modern dual coil one with an immersion heater inset half way up. I'm hoping it will heat more of the tank than the current one via the PV dump. I also looked at a solar array with a water feed to the second coil in the tank. It seems, for now, that the PV dump is cheaper and easier to implement.
We plan to insulate the remaining walls which will benefit from it. Interesting thoughts about engaging a specialist to do it rather than a normal builder.
I looked at adding solar batteries but my maths suggest that the pay back is excessively long. We will wait and see how things pan out with battery technology and increasing per unit costs of electricity. There is space form battery and it may help with a BEV car, when we finally give in.
We have a nest thermostat in our current house and this works fairly well (except when it goes off on a crusade to try and save us cost). The new place probably wont benefit as each room is individually controlled. It would be an expensive toy to simply control when the hot water is heated.
We've looked in ASHP and GSHP. Time will tell but both don't appear viable at the moment - certainly we want to give it a year while we gather data. Some of the old incentives offered by the Government would have been helpful but the new scheme seems excellent at hype and less excellent at financial incentivisation. We have the space for a GSHP but the thought of digging up hundreds of square metres of a field are not very palatable. Sinking vertical bores are prohibitively expensive. The house derives its water from a vertical bore hole and it may be possible to run a GSHP via this (but it's expensive to do). Equally, it may be possible to utilise the adjoining river as a GS - but I'd have to investigate this with an expert.
ASHP is less disruptive and it feeds nicely into the wet underfloor heating. While I accept that it is about 300% efficient, it's still a massive outlay and the variation in air temperature (as opposed to the relatively constant temperature of the ground) concerns me - when really cold, energy being made up with electric heating (which is still expensive) and I cant use the solar PV as the yield is typically low in winter. Perhaps an ASHP could be combined with the existing oil boiler rather than electric ? I need to consider the space requirements.
We've also considered biomass - at the moment I'm not convinced that we have the space for a boiler and a hopper. We do have a ready supply of wood on the land to run the wood fires but I doubt we have enough to run a biomass.
We also looked at wind turbines. They would complement the solar but I was amazed how expensive a decent turbine is. Once again, the ROI is long.
This, I feel, is the big conundrum for all of us: we are all stuffed with increasing costs of energy for our homes. Aside from the low, but very effective, hanging fruit such as wall and roof insulation, most of the other systems have a pretty big outlay, are massively disruptive to install properly in older homes and suffer from a pretty long payback time. Government incentives and grants, while helpful, go a long way to hype the politics and green credentials but do a lot less in really helping with the up front costs. Much of it seems like window dressing. Especially now, where wallets are under pressure, adopting this new stuff for ecological reasons requires deep pockets and adopting it to save money needs very careful investigation before pressing the button.
Slightly off topic but must put balanced view. Firstly my wife and I don't have many big meetings in our house so do not stretch the boiling tap beyond capacity. I was cynical based on work type boiling taps always breaking down. However fitted a Grohe tap with I think 4 litre tank and it has been fantastic, make a hot drink whenever without messy kettle standing about and it tastes good which was also a concern, would never go back to a kettle. Grohe filters are stupid price but if I could be bothered I could swap out for cheaper make, but don't change them that often once a year maybe.I would avoid like the plague if the recent batch of instant hot water taps advertised for the domestic market are anything like the Zip hydrotap that were being installed in government buildings about 15 years ago, they quickly used very expensive filters and couldn't cope with the rush after a meeting ended, kettles had to be reissued as backups. This was at the same time as they installed the overpriced and useless Dyson hand driers.
Same with our house; perhaps they didn't think it was worth saving!somehow, the place escaped listing - which I am not complaining about!
We built a bungalow about 20 years ago and paid a token value of about £200 each for electricity, telephone and water. They all came and installed temporary connections in that price. BT managed to put the pole in the wrong place and came back and moved it. I was speaking to a guy having a house built for him and the water company want £15,000 to make a connection and he has to lay a pipe to where the connection will be. I think he said the electricity company wanted about the same.£100 to install
We can tell when our filter needs changing as the nozzle starts furring up. I use the cheaper filter from Amazon and they work OK.change them that often once a year maybe
I have had a lot of dealing with UKPN for power to lay connection to the DSLAM broadband cabinets and their general rule is if your point of connection to a serving main is 43 metre or less they just charge for a service connection, if it's is over that they charge you for extending the network for them and it runs into big money depending on distance of course. Openreach are similar they can/will/maybe charge for network costs to get from curtilage down to your property e.g a farm with long track. They don't usually charge for extending the network within public highway unlike UKPN.We built a bungalow about 20 years ago and paid a token value of about £200 each for electricity, telephone and water. They all came and installed temporary connections in that price. BT managed to put the pole in the wrong place and came back and moved it. I was speaking to a guy having a house built for him and the water company want £15,000 to make a connection and he has to lay a pipe to where the connection will be. I think he said the electricity company wanted about the same.
I’ve done exactly this on my 1885 granite walled property. We had Icynene permeable foam poured into the space between the lathe & plaster and the external walls. You should research this foam and the few companies set up to install it. Our home is transformed: draughts gone (esp around windows), massively warmer and quieter. We sprayed Icynene between the roof trusses also and so have a warm clean and dry loft. There’s lots of ignorance and doubt about this type of permeable foam, and you’ll find a lot of people have not heard of it, or are very sceptical. Check out the 10yr+ research done by Scottish Heritage to validate it’s effectiveness at isolation and also in avoiding damp.Insulation will reduce operating costs of any system, but how to insulate a lath and plaster, solid granite wall construction. Put on a jumper and turn the thermostat down.
Large bore piping with increase efficiency too - insulated if course..
I've been mulling similar of late as I have an old granite house with a combi gas boiler, Scotland plans to get rid of all gas heating in the next ten years. My thoughts/understanding in this area:
- The highest heat demand on the gas boiler comes from DHW rather than CH, so the 'boiler' size can be reduced via a HW tank which can be charged with hot water when CH is not demanding.
- Modern combi gas boilers are 90+% efficient
Fitz
- Insulation will reduce operating costs of any system, but how to insulate a lath and plaster, solid granite wall construction. Put on a jumper and turn the thermostat down.
