Any gas heating engineers on the forum? Advice needed.
ey_tony
2 Nov 2015
North Yorkshire
Hi guys, last week my gas boiler finally gave up the ghost after 27 years of service. The boiler an IDEAL Classic RS250.
I called someone out today to give me a price and a more or less 'modern like for like swap was quoted as £2900.00 for the swap (equivalent modern Ideal boiler) including Hive smart thermostat.
The brickwork around the new small diameter flue will need doing but other than that it's virtually a straight swap. The house is a compact 4 bed detached just over 25 years old.
To be honest I haven't a clue with regard to pricing these days so if there are any heating engineers reading this, is this a fair price?
Get more quotes and also make sure the price includes a system flush and a filter is included as you may not have one on the old system. Also the new boiler will be a condensing type and require a condensate pipe to a drain which will all be new so a little more work. So get more quotes and make sure they are listing what that entails so you have no surprises and can do fair comparisons between the quotes.
Thanks Spectric...will do that.
My experience of ideal classics is they were good system boilers , cast iron heat exchanger etc but they were prone to condensation and rotted from the inside to out - parts are limited and expensive so new boiler is the best solution. As per @Spectric system flush. and filter is essential. And get several quotes insist on a valiant or Worcester Bosch as imo these are the best . Usually the cheaper the quote the cheaper the cheaper boilers will be fitted ( ferrolli biasi etc ) also they tend to just drain fit new boiler and fill up and Fxxk off leaving your new boiler to circulate old , sludged and contaminated water through equally sludged radiators. Try this - apply a magnet to any copper pipe in the airing cupboard and if it is attracted to the pipe then the pipe contains sludge ( iron oxide ) hope this helps ..
Typically, around here (Northampton) quotes are £3.5k to £4k, but that would be for a Vaillant or Worcester Bosch and include a flush, fitment of magnetic filter and the aforementioned condensate drain.
If replacing a standard boiler with a combi, there may well be additional costs such as removal of the hot water cylinder and fixing any leaks in the now - pressurised hot water pipework
If you have a system boiler with hot water tank then keep that system, combi's are not as efficient and can have higher maintenance cost over there lifetime but some might try and push you down that route, either way modern boilers will be hard pushed to give 27 years of service.
