Sheptonphil
Scrumpy junkie
After spending last summer building my new workshop, I have now embarked on a summerhouse for he good lady.
After looking at various designs, she had her mind set on a pyramid roofed open fronted summerhouse. We have a corner of the garden which lent itself to a 6m x 4m structure, so I put in for planning permission. We have no permitted development here so everything has to go to planning. It’s no great hardship and it does mean I don’t have to keep to height and size restrictions of PD.
Starting out with a rather untidy corner which we planned to have this summerhouse here so never tidied it up.
the garden is slightly sloped and this is going to be built on 500mm deep concrete piles. Bedrock is 350mm below the surface.
Main uprights bolted to the anchors set into the piles With 6x2 frame let into the tops of the 5” posts.
Corner braces made from 6x2 for each joint
Setting out the joists and setting in a mid width support with joist hangers. Support has six supports 400mm concreted into the ground
Temporary support for the ridge beam before adding commons and hips
