johna.clements
You must have a big cat to use that cat flap.
no reason not to add the battens I don't think.Put on battens to hold down Tyvek until cladding arrives or leave battens off to avoid possible water - opinions? We had a bit of wind yesterday and I had to rush out and put more staples in but it seems to have held up. Cladding may or may not be fitted until next year
What this man said is the correct way if you are using vertical cladding. I was a cheap skate and did not do this, I simply angled the top of each batten on the planer so that any water did not pool against the membrane. This however meant I planed away the tanalising (sp?) chemical so all my battens will rot early and the cladding will fall off. So is the will of the shed building gods.no reason not to add the battens I don't think.
Ensure they are vertical, not horizontal, so that water cannot pool, and if they need to be horizontal because your cladding is vertical then you need to double batten:
vert batten -> horiz batten -> vert cladding
Check Tyvek website for UV resilience, it should be waterproof but its not designed to be in the sun so might have a UV volatility
Martin
Tyvek (type stuff) went on today, after routing out the window, which was going well until the bit lost its bearing
Added a small radius on all the sharp edges while I had the router out to avoid any tears.
Great fun putting that on in the wind and rain!
I'd put on battens tbh.
And cladding asap too..
Martin
The step you are about to make is one which I almost screwed up, the door fitting. I didn't really think about the battens and cladding depth when positioning the doors and windows, I just defaulted into placing in the middle of the wall. My thinking was that I wanted the reveals to be same size on both sides. It is the sill that needs thinking about though... I got lucky and the sill protruded past the cladding, but only because I did horizontal cladding and hence had only one layer of battens.Hadn’t thought of all that, I think the cladding will be vertical and I was just mulling over angling the battens but it all makes good sense. Thanks!
Haha, nice idea though!What this man said is the correct way if you are using vertical cladding. I was a cheap skate and did not do this, I simply angled the top of each batten on the planer so that any water did not pool against the membrane. This however meant I planed away the tanalising (sp?) chemical so all my battens will rot early and the cladding will fall off. So is the will of the shed building gods.
I didn't fit them myself, just instructed the door fitters where to put them... when they asked me I hadn't really thought it through and almost randomly made that decision.
Think about your sill depth too, this is usually configurable, so have a think about what you want and need
Martin
Martin
I’m thinking about doing the back and sides in steel, corrugated or similar. Can’t make my mind up whether the batten orientation makes any difference, if I go straight to horizontal? (Or not, and put the sheeting the other way like this, but I’m not so sure…)
I could vent it into the soffit without too much trouble, then seal it along the top. It looks like insect mesh is available for profiled stuff but I’m not sure how effective it would be, tempted not to bother, I’m not sure how much of a pest insects could be (famous last words)That’s a pretty cool look, interesting solution for cladding. The battens give an attachment point for the cladding and create a air gap that can dry out is water penetrates the cladding which is just a ‘rain screen’.
With corrugated steel being impermeable you may argue that there will be no rain penetration so it’s irrelevant. If you wanted belt and braces I’d want this gap to breath so I would run the battens vertically and ensure a gap top and bottom with and insect mesh barrier.
I have a few famous last word potentials with my shed. I think you understand the ideal and the trouble providing it, then you make a decision and history will be the judge.I could vent it into the soffit without too much trouble, then seal it along the top. It looks like insect mesh is available for profiled stuff but I’m not sure how effective it would be, tempted not to bother, I’m not sure how much of a pest insects could be (famous last words)
Wasp nests would block the ventilation ....I’m not sure how much of a pest insects could be
I’ve got an air compressor and a small boy who can run quite fast…Wasp nests would block the ventilation ....
