Found some random no brand (Chinese origin) membrane I bought for something else years ago and forgot about, is there any reason not to use this? It seems to do the job, left the tap on it for a few minutes and the water didn’t get through.
Why not looks fine...Found some random no brand (Chinese origin) membrane I bought for something else years ago and forgot about, is there any reason not to use this? It seems to do the job, left the tap on it for a few minutes and the water didn’t get through.
If leaving any time the put a ridge pole up to drain off water.
A bit of 4x2 in the workmate in the middle would do too.
BLACK!Thinking about going for a darker colour, might be able to get away with cheaper cladding if it doesn’t have to be pretty.
Wife isn’t sure
Any fall to that roof?
Price of oil....Just priced up UPVC facias - £400! Think I could get it down a little bit elsewhere but I wasn’t anticipating paying anything like that. I would simply fold over the rubber like @Fitzroy did, looks great, but I’ve always planned on having a gutter on this (I plan to chuck sheet materials behind it as much as anything). So I might get a hop on to sort out the cladding so I can use this for the facias, or maybe figure out a way to put a kerb around the edge with the EPDM, I’m not sure how the manufactured kerbs would look if I did it fitz style.
i used this mesh to stop critters getting under my shed, nailed the bearers all the way round the baseWith this design, once you have the base in place use wire mesh of some sort to seal all the edges to prevent rodents living underneath, mesh size will determine who can get in!
I think I’ll have to find something like Hardieboard or Cedral, but it’s not easy (cheap) to get hold of in small quantities and I don’t really want to use it for the whole shed. Found some larch cladding nearby, but it’s finding time to go and have a look, I’m away overnight with work almost every day for 3 weeks now. Can’t decide if I should go vertical or horizontal with the cladding but I don’t really want any joints and I can’t find lengths over 3.6m so that’s probably the answer. The waste from doing it vertically will do the eaves and windows. Need to get the roof on before it gets too cold - 4deg for the rubber. Might just buy it and leave it overhanging until I figure out a facia. Only have a temporary door/hatch.Tyvek would get ripped eventually.
UV will also damage it.
