Hi,I’ve got an air compressor and a small boy who can run quite fast…
You can buy upvc cill material.
Or use a 4x2 with the corner planned off.
Looks about right. I used that Dupont flexwrap stuff in addition to your layout but I don't think I needed to. It gives a more complete seal on the internal frame but I don't see water getting in there anyway.Bit of a break doing other things, plus the vented soffits still haven't turned up and I want to have a look at it fitted before I make a decision about cladding, but I'm pretty set on corrugated steel on the side and rear (probably galv or painted black to keep it 'non-combustible' as I found out from another member that the plastisol coated stuff will be combustible).
I think I mentioned that the UPVC window I got didn't come with a sill. Any comments on this arrangement?
Just seems like a lot of extra cost & effort to be honest, just be mindful, as I said, about the drainage holes in the windows.I think a wooden sill matching the cladding would look better
That's the way we do it, just fold it in and cut it off to the inside face.a lot of people wrap it inside the building but think cutting it halfway inside the frame makes better sense?
Also why not use 9mm OSB rather than 11mm, its manufactured principally for this purpose, its nominally smaller though, to allow for expansion gaps.
I have just built a 5m x 3m studio with a similar design. Just a few points.
EPDM was easy to install and looks great, there is no way I would suggest using anything else.
TYVEK house wrap is brilliant (although expensive), I injured my back during my build and had to delay things. The wrap has been stapled and battened on for about 18mths now and is still fully protecting the building waiting for me to finish the cladding.
I used 70mm PIR insulation in the walls with it tight up against the plasterboard. In retrospect it would probably have been cheaper and just as good to use 50mm centred in the cavity. The silver foil reflects heat only if there is an air cavity.
I used 9 Very solid (dug down 18” nearly to chalk bed, 5” reinforced concrete and three blocks) supports for the base and 5” timber, I think your method of more blocks but no foundations will prove to be better and much less work.
Don’t skimp on anything especially lighting and sockets. I think I spent five times longer researching, designing, planning and costing than building. Loved every minute. Enjoy the rest of the build.
Careful doing that - generally speaking, centering PIR inside a cavity is not good, it would create an air pocket adjacent to the cold side. It does depend on your wall design though, if you don't have any external sheathing it's probably ok, if you do have external sheathing its probably not ok, especially if it's OSBI used 70mm PIR insulation in the walls with it tight up against the plasterboard. In retrospect it would probably have been cheaper and just as good to use 50mm centred in the cavity. The silver foil reflects heat only if there is an air cavity.
