Yojevol
Clocking on
Background
It must be 20 years ago that we bought this bucky ball lampshade for our bedroom although I didn't know it was bucky at the time. I would lie awake looking up at this new feature fascinated by its design and construction. How could such a complicated structure be made for such a modest price? (BHS Lighting Dept). Studying it from the comfort of my pillow I realised it was made up of 5 and 6 petalled florets and what’s more it had the regular structure . Each 5-petalled floret is surrounded by 6-petalled florets and each of the 6-petalled is surrounded by 3 x 5's and 3 x 6's. This arrangement, being reminiscent of a modern football, gave me a lead in to study the ‘ball’. It turns out that it has a formal name - wait for it - ‘Truncated Icosahedron'.
The common-or-garden plain icosahedron; one of the platonic solids (the Greeks were into these things). It has 20 faces (icosa = 20 in ancient Greek and hedron = faces) which all fit together perfectly:-
Truncated Icosahedron as a moniker doesn’t roll off the tongue too easily so it has acquired the nickname of ‘Bucky Ball’. Therein lies another story:-
Richard Buckminster Fuller was (he died in 1983) a renowned American architect who developed the geodesic form of construction (think Eden Project) which is based on the basic icosahedron. His name is also applied to the many molecular forms which are known as ‘Fullerines’
About the same time as acquiring the lampshade I was beginning to get adventurous in the use of TurboCad. So why not, I thought, just for the satisfaction of it, produce a bucky ball in CAD?
I spent a lot of time fruitlessly hunting around for some geometrical clues to get me underway. I just couldn't see how to get started, but then it struck me; just do what I normally do when detailing a bit of woodwork, ie. simulate in CAD what I would do in reality in the workshop.
In this case, if I were making a Bucky Ball out of card, I would start off like this:-
Keeping HexA flat on the worksurface, simply fold B and C up to close the gap and glue. →
It’s not so easy in CAD because you can only move one item at a time and you don’t know where to rotate it to.
So a few construction lines are required to determine where the adjacent corners meet. Now B and C can be rotated up, one at a time, to the desired position. This provides the basis for the whole Bucky Ball construction.↓
An Idea Develops
Perhaps inspired by @pjm699's design, I started to think about the possibilities of making a bucky ball in wood. The obvious hurdle to over come would be the making 32 facets with sufficient precision to fit them all together accurately. It was only after I kitted myself out with a CNC router that I contemplated the means to make them accurately and in quantity.
My thoughts went back to the design. I wanted more than just a ball with holes in it.
Back to the lampshade in the bedroom; make a bucky light; hang a bulb in the middle.
No, too easy, too boring. Have separate lamps shining out of each hole. No, still too easy.
Have something that draws the eye INTO the ball.
Yes, Yes; a light feature that draws attention. Now that would be a conversation piece.
I'll leave the details of the individual lamp unit design hanging in the air for the time being and concentrate on the woodwork.
The basic bucky ball needs, to my mind, a little something to make it more distinctive and attractive, that little bit of finesse. So I'll introduce a **** bead between each of the facets in a contrasting wood.
Other details are:-
Prototypes and Jigs
I've spent many weeks getting to the stage where I'm confident to actually start manufacture. During this time I have experimented with procedures and jig design. These will become evident as I go through the job.
Work-in-Progress
This will be a true WIP. I'll report as I do it. It may turn out to be a long drawn out process.
There's always the possibility it won't be successful. Even if it is successful I may not actually like it or I may be refused permission to deploy it but, whatever, the journey will be worth the effort
Brian
To get to the truncated version all the pointed peaks are truncated (chopped off), like this:-
Thus the familiar football appears. It has 20 hexagonal faces, 12 pentagons and 60 vertices. This structure is hugely important in the 21st century because carbon atoms can spontaneously coalesce into this molecular form (Carbon60) with an atom at each vertex . It is commonly found in soot. The beauty of it is that it can be elongated into tubes by adding in extra rings of hexagons to form immensely strong carbon tubular fibres.Truncated Icosahedron as a moniker doesn’t roll off the tongue too easily so it has acquired the nickname of ‘Bucky Ball’. Therein lies another story:-
This was my ultimate interpretation of a bucky ball in CAD →
An Idea Develops
Other details are:-
- 2 sizes of lamps; one for the hexagons and a smaller one for the pentagons
- lamp orifices edges rounded over.
- top and bottom pentagons will be lamp free.
- ball will be made in 2 halves, top and bottom. so that it can be split to allow access to the electrics inside
- 2 halves will be joined together with an internal threaded rod connecting the top and bottom pentagons (hence the plain panels).
- woods will be American Black Walnut and ramin
- support, will be a stand or hang from the ceiling, yet to be decided.
Prototypes and Jigs
Work-in-Progress
Brian
