The lamp is now complete but it hasn't been plain sailing since my last report. Having got it fully assembled I powered it up for a soak test and was alarmed to find the temperature had risen to 45°C. I tried boring 5 ventilation holes top and bottom but this made little difference. This was using a mains powered 12V supply. I then tried a 9V supply which certainly cured the heat problem but the light level was much diminished. It was then time to throw some money at it and purchase a 40W supply intended for LED use. That, together with a dimmer switch, has solved the problem.
The other issue to resolve was fairly cosmetic. I could have let it go but it was annoying me. I made the ball in two halves, top and bottom, but I didn't take enough care when gluing up that they would fit together perfectly. Some of the **** bead halves were not coming together nicely along the join line. So I stripped off the offending beads and replaced them bespoke beads which were made as single beads - not 2 halves. With a bit of fettling and filling of gaps with walnut veneer it's now much more presentable.
With all this unplanned remedial work I felt it was in need of another coat of lacquer. However I wanted to avoid spray on the lamp lenses so the needed to be masked in some way. The easiest way was to make a number of discs and hold them in place with a dob of Bluetack. So, how to make 30 discs to specific diameters:-
Retrieve a bit of scrap plywood from the woodstove pile
Cut it into squares large enough to make the discs
Glue the squares together to form a cross-grain length
Mount in lathe and turn down to required diameters
Chop off discs salami style with saw - I found the bandsaw was best for this as the mitre saw tended to fling them across the workshop.
That took about an hour including half of which was waiting for the PVA to cure.
And here it is ready for a respray:-
