Hot Tub
JonnyD
10 Mar 2008
Lincolnshire
A bit of fun for a Friday. A load of larch was delivered and we started with the base. The T&G boards were held temporarily underneath whilst a circle was routed out to 1.75m diameter
The boarding was pre machined but a housing was needed to fit over the base so this was done on the RAS
The boards were placed around the base and pulled in with some large ratchet straps.
Over she goes
You can see the metal straps holding it together here
The heating is done by woodburner which you can see here.
Jon
Excuse my ignorance Jon but what keeps the water in? Is it just a tight fit like a barrel or are the planks glued together? You can tell I know nothing about hot tubs. (I can tell you all about gazebos to cover them) :lol:
Barrels are not watertight because they are tight, it is the moisture which swells the oak thus sealing the already tight joints, let one dry out and it will fall apart.
Andy
Ooo... very cool!
I'll be going incognito :-" when following this project ... otherwise SWIMBO will want one! :lol:
I imagine it'll be like floating a strip planked boat which sinks initially until all the planking expands... but the opposite if you catch my drift :wink:
Thanks for the interest the parts were purchased from logosol along with the timber to go with it see here http://www.logosol.com/store/uk/index.p ... ksbad.html
The idea is as has already been said that the water expands the joints and makes it all tight and leak free.
Had a few bits to finish of in the workshop some galvanised support brackets were coach screwed to the sides to take the seating and the burner was bolted to the side of the tub.
Got some muscle in to load onto my trailer was too heavy to lift so was rolled .
A guard was made for the woodburner and in this pic you can see the finished seating as well
Filling started and there were a few leaks from the bottom but only slight. As the cold water went in it kept the beers cold.
It took about 3 hours to fill and get to 35 degrees.
In use
A bit of over exuberant use of the wood burner meant the water got up to a toasty 48 degrees. Overnight a spare sheet of celotox insulation was put over and it was still very hot in the morning. Leaks are now a minimum about 10mm of depth lost over night.
Overall a fun project and another one has been ordered today for a mate.
Jon
Doug B":2rydnzmc said:
Top work Johnlar,
Will it be available to use at your next workshop open day?
Room for 6 standard people, or one Matty :lol:
Matty in a hot tub, there's an image that could lead to a need for counselling :shock:
Just joshing Matty xxx :D
