Workshop Fire Safety - Networked Fire Alarms
Sideways
Moderator
Staff member
Moderator
UKW Supporter
26 Dec 2017
United Kingdom
I'm a member of a mailing list on "groups.io", the old yahoo.groups, used by owners of Harrison metalworking lathes to keep in touch and help each other out.
A member of the mailing list recently shared the bad news that he lost his entire workshop including some heavyweight lathes and milling machines, in a sizeable fire. Think 40 firefighters in attendance !
Fortunately he was insured but it is still massively disruptive.
It got me wondering, like probably everyone else, how safe is my own workshop ? what are the biggest risks ? what could I do to improve ?
As my workshop is the garage attached to our house, I realised that one of the obvious things I've overlooked is a smoke / heat alarm with some sort of remote that would sound off inside the house if a fire developed after I had finished and closed up the workshop for the day.
The answer seems to be the newer style smoke alarms that are radio linked so one goes off, all go off.
There are many end user complaints about the types that rely on a 10 year lithium battery only lasting 2 or 3 years in practice, with poor customer service and inadequate guarantees. The cost of remote type alarms is high if they have battery powered but achieve only a short life and not the 10 years claimed. I guess I need alarms that can be mains powered and have replaceable batteries for backup.
I don't want a google smart thing. Just not reliable enough, but I would be very interested in any recommendations please.
Thanks in advance.
My immediate thought - prevention is better than cure - so have a look at all sources of potential fire starting. Don't forget spontaneous combustion risks - like rags in bins.
Second - maybe if you can install a sprinkler to give you a head start in extinguishing it.
Then a mains smoke alarm system is good - but even they do have a life and we just replaced ours after 10 years - so make sure you get a main brand which will be around in 10 years - that way to replace just the head not base as well. Link them all up to the house - because priority number one has to be the safe evacuation of you and yours. I am not sure they are linked via radio - I think the signal goes through the wiring. Certainly with ours the upstairs landing one goes off as well when it is supper time. Heat detectors are good as well - just get the right type - I think those for kitchens are designed to trigger with a more rapid rise in temperature.
Do post back what you decide on - will be an interesting thread.
Although there are 'radio' ones out there- I'd stay clear of them- they tend to have rather short ranges (especially if going through multiple walls) the lower the signal, the harder they pull on the battery!!!- wired ones tend to be a LOT easier to set up (especially in attached buildings where you can access the ceilings of each point from the loft lol)
Although it isn't an actual requirement (yet...AFAIK) it is advisable to use the 'red smoke alarm mains cable' rather than just standard mains cable- so it can be identified easily and someone doesn't 'tap into it' later on, plus they are usually 4 core for the 'group alarm' systems (ie Active, Neutral, Earth and Signal/Alarm)
Plus of course, it is best to have them have their own feed from the consumer unit, rather than 'sharing the lights' as was often done with older installs- what happens if it is a faulty light that starts the fire- and kills the power to the lighting circuit????- oops, you just lost everything except the local alarm in there!!!
The aico products look good.
The 3000 series have the mains power with rechargeable lithium backup (upto 6 months) that I am looking for.
They network by hard wiring, and have optional radio module that can be fitted in the detectors to allow them to network by radio (which is much easier as I can't just run wires inside a loft, I would need to go through external walls.
The smoke and heat sensors are available, and together with CO detectors. All the bases covered.
I can't immediately understand whether their gsm gateway module is mandatory to use the radio networking. If so this will rule the brand out. I will not sign up to a service contract for a fire alarm system and don't want a remote system that uses a GSM SIM card for data.
It's understandable that aico want to offer a remote access service that doesn't rely on the householders wifi, but I'm not a customer for that service. I just want the alarms to squawk together.
Mine have battery backup. Not sure if that still triggers the others on the circuit or not though.
I've got a heat alarm in the garage (attached to house on the side) that is linked into the house ones, so if my garage is merrily burning I know to get out the house.
I posted a while ago about fire extinguishers and there were some interesting ones about, including ones that hang from the ceiling and automatically go off in a fire.
This has reminded me to test my alarms again.
And both the fire mentioned in post #1 and one on UKW from some time ago has got me looking at the Fire Safety Stick extinguishers. 50 and 100 second burn times, open the door, toss one in and leave to suppress the fire are very interesting features.
Italian innovation that has been getting better established here over recent years.
Which ones do you use and would you recommend ?
Mine are made by Hispec https://www.hispec.co.uk/interconne...echargeable-lithium-battery-backup-1794-p.asp
mine are the older version though so don't know if the new ones will connect, might drop them an email to check as I am planning an extension next year so will want some more. Mine also use 9v square batteries and will warn you if they are low. I assume if the lithium batteries in the new ones fail then you have to replace the entire unit, but that seems pretty common these days.
Don't know whether or not to recommend them as such, they sit there with a green light so hopefully will work when needed. They are En/BS rated so should meet min standards. I also have a separate battery smoke alarm from before I had these that I just have as an extra around the place so I'm covered if these ones aren't great. I'm not overly paranoid about fire but I do have a wood stove in the living room and have a lot of wood and chemicals in the garage so I'd rather have the earliest warning I can.
I do have mine on a separate mcb also, although ideally I guess it should be on an RCBO separate from all the other circuits so if the main RCD goes it doesn't turn them off, but then that's what the battery backup is for in worst case scenario.
And both the fire mentioned in post #1 and one on UKW from some time ago has got me looking at the Fire Stick extinguishers. 50 and 100 second burn times, open the door, toss one in and leave to suppress the fire are very interesting features.
They also have a much longer shelf life than other extinguishers
