PeteG
I've probably committed a cardinal sin not drawing any plans up, but here goes. I've started on the storage cupboard for the workshop, hopefully the below image will give you an idea of what I'm up to, although I doubt it will look anything like these superimposed wardrobes. The freezer will sit on a small plinth in the corner.
I've made the base frame on top of which will lay a sheet of 3/4" plywood. From right to left will be two units with an internal dimension of 2' x 2'. I've 12 sheets 8' x 2', total length of the cupboard is around 8'6". I've cut 6 sheets in to 6 foot lengths, leaving the 2 foot off cuts as the top, bottom and shelves for the first unit, top and bottom for the second unit. I'll be using the pocket hole jig to join these up. The third unit will be 4'6" x 2'...
Now for the questions?
1: The frame was made up of planed 3" x 2" Redwood and joined using the pocket hole jig, I had one small cut out to make in the left corner [ See below image ]. Once a sheet of ply is layed on top, the front of the base is around
2mm lower than the back! Will this be OK, or do I need to lift the frame some how at the front? The floor is roughly finished concrete painted.
2: The third unit being around 4'6" x 2", is this too big to be using pocket holes and should I be adding some frame work?
3: Once all three units are made up, I was going to screw them all together, then to the base and the back wall, which is sheet chipboard. Does this seem OK?
4: The first unit I'll be adding shelves, again using pocket holes, these will have an internal dimension of 2' x 2'. Do you think shelves and plastic boxes are the way to go, or would I be best off making draws on runners?
5: Doors! Do I make doors on hinges, and if so, is there a certain type I need? Or would sliding doors be a better solution?
Any advice would be greatly appreciated chaps, after the bench, this is the BIGGEST project I've attempted!
Pete.
Pete.
