Workbench Build
Having spent weeks stripping lathe and plaster and planning to remake the bedroom window I decided it would be easier if I had the workbench semi functional rather than in pieces taking up space in the shed. So I’ve drilled the end frames ready for drawboring, shaped the vice chop, and planed and sanded all the frame components.
Just need to think the build plan through one last time to make sure I’m not forgetting something that will be much more difficult once the frames are together!
End frame and leg vice ready to drawbore.
Vice chop shaped and sanded. Think I like the waney edge but still a little uncertain.
Heavy chamfers on all components hide a multitude of mistakes!
Fitz
Seems to be a thing to have a statement piece of flashy stuff for the leg and that certainly fits the bill! I think the scollops out are fine, you certainly don’t want anything that would be rough or jagged.
Bench was assembled ‘again’ as I needed the space to build windows. The top needs to be flattened and I’ve not worked out the tail vice yet. The leg vice got a piece of leather on the jaw and has seen some use, I’m loving the action of the vice and the cross works well.
Frame was finished in OSMO Raw 3044 to try to keep the sycamore light, elm vice jaw finished in Danish oil.
I’ve realised I do nearly all my hand cutting over the right hand end of the bench so a tail vice is really going to be in the way. As tail vices are common I’m left wondering how folks cut to length. Hmmm.
Fitz
