flying haggis
davy_owen_88":3qt08h4g said:If they are metal-clad CU's then yes, but if they are plastic you will need to terminate them into a metal adaptable box and then use 6mm² t&e to join SWA to the CU.
Here are some links to the things you will need:
Underground warning tape
60A connector strip
SWA glands
3-core 6mm² SWA
Green & yellow sleeving
Metal adaptable box
not necessary to use a metal box to terminate but if you do, fix metal box next to CU ie touching then fix gland to metal box and take cores of SWA through metal box into CU. OR fix gland onto CU then earth armour using piranha nut
