matt
I'm about to replace the side gate the leads to the side passage between my house and garage. The current gate has a fixed frame piece across the top, making it difficult/impossible to take extra large items down the side of the house.
The electrical supply to the garage currently uses this fixed frame piece as it's route. It comes out of the eves (chalet style house with "low" side nearest the garage), along the wall a short space, across the frame, and through the garage wall.
When I replace the gate, I plan to remove the fixed frame across the top and re-route the wiring. I realise this will require part P etc, therefore, I'm after a compliant solution.
I have some armoured cable, however, it's a right pain to make it look neat with so many twists and turns - I get exhausted just thinking about working with it in such a small space. Therefore, I'm thinking I could install some conduit that runs from the eaves, down the wall, under that flags in the side passage, up the outside of the garage and through the wall. I'd have to extend the cable, therefore, would create a junction as it appears from the eaves (or, better still, inside if I can get to it), but just join extra 2.5 run through the conduit. I have a consumer unit in the garage where the supply line will terminate before being distributed via a ring.
Does this sound like a plan?
