Door is completed and finally I can lock the place up, roof edges are done and take a look at my awesome workbench!
I used aquamac 21 seal to give me a good seal around the door perimeter. I want the workshop to be as airtight as possible so that the dehumidifier can keep the place at a decent/constant)(ish) humidity, minimising the impact on timber and tools. Seal was £10 for £10 meters off eBay.
Seal uses a 2.7mm recess to push fit into, turns out most table saw blades are about the same.
My table saw is an old beast with minimal guarding but managed to rig something up that pretty much eliminated the chance of coming in contact with the blade.
Seal push fits in the gap, found the ends didn't want to stay put at times but a little superglue fixed that.
Once the door seal was fitted I sized the timber to fit around the door perimeter and fill the gap between door and frame. Turned out either the door or opening were not square by about 3-5mm so took a fair bit of hand planing bespoke fit each side, top and bottom.
The depth of the door (150mm) and the closing circle from the hinge meant that I had to profile the edge board of the door, which was a real pain but got it fitted in the end. The door is also marginally twisted, with the bottom left corner protruding about 10mm further out. The lock is fitted to the same corner and it's easy enough to push the door flush and close the lock.
Eventually there will be a lock top and bottom and a latching handle in the middle so you can close the door to whilst inside, but for now at least it has a lock on it!
I also fitted the final roof edging.
Whilst sitting eating my lunch I thought i'd share a picture of the 'workbench' i've been using during the build. Last summer my boys asked for a 'house' they could play in so I screwed a few off cuts of framing timber and OSB together, lay a board on top and called it a house. After bringing it in from the weather at the end of the day i started to use it as a workbench. It's out of level and square, and very rickety, but it's now screwed to the floor by one leg, and braced against the shed wall via board offcuts lying on the floor and it's good enough to let me, saw to length, plane edges, and sand. I'm actually amazed at how simple, and out of cock, a bench can be and still be functional.
Fitz.
PS. Again photos are displaying odd, the are all the correct way up in my computer and when you click on them, but are upside down on the forum post. No idea how to fix, gah!
