YesParanoid moi?
it is just you. No problems here.is it just me or is this site almost unusable
Yeah - just paranoid.is it just me or is this site almost unusable, writing anything is taking forever, sometimes when the backspace is used whole sentences are lost. I am not having any problems anywhere else- at all!
It seems strange that this started when I criticised one of the advertisers on here.
Paranoid moi?
I've had exactly the same and put it down to being busier as well. I've even gone to another page at times to do a speed test in case but that's OKYeah - just paranoid.
But I've also had a few occasions recently when the site was slow to respond. Cloudflare popping up and saying it had timed out and the like. Maybe the internet was just getting hammered over the Christmas holiday![]()
In terms of hand safety it's 99% of the essential knowledge. About as simple and obvious as not putting your hands near a fire!...... knowing not to put ones hands too close is part of that essential knowledge, ,,,,,,
Yebbut then how do you light itAbout as simple and obvious as not putting your hands near a fire!
Hmm, got me there.Yebbut then how do you light it![]()
Hmm, got me there.
Get one of the servants to do it?
Worst cold we've ever had! Coughing and sneezing 24/7. Had jabs for covid and flu so not either of those. Even went off food and drink. Just starting to catch up with a bottle of red.
hope you’re both feeling better![]()
Just because you had a flu shot doesn't mean you won't get it. If the strain of virus isn't the ones they guessed would be needed and made the vaccine for, you can still get it. Keep drinking the water so you don't get dehydrated. Suck it up buttercup and get better.
Not only that but even if vaccinated for the correct strain you can still catch it you just won’t get it as badly as if you were not vaccinatedJust because you had a flu shot doesn't mean you won't get it. If the strain of virus isn't the ones they guessed would be needed and made the vaccine for,
Chainsaw trousers could actually contribute to an accident with these machines, as the ballistic nylon/kevlar liner is far stronger than say, denim. Thus you've no chance of pulling free.Are talking about one of these machines . I’ve hired one several times over the last year or two to remove anything from small tree stumps to huge 36/48 “ beasts . I can understand the need to remove ( bricks , concrete , steel etc ) but simply can’t fathom why anyone would want to get anywhere near that blade . Our procedure was to drop the revs to minimum and swing the machine away from the cut zone , once the rock etc was removed and cleared then my mate would remove himself from the area and the machine would be repositioned and continue with the stump . Re chainsaw trousers - while I’m more than confident in them when using my chainsaws to prevent serious injury from a very fast and sharp chain of teeth I don’t think it would make any difference to this machine . It does have a large ,heavy , steel disc but it has what I can only describe as two bolts for teeth top and bottom of the disc and by design the fibres in class 1 or 2 chainsaw trousers would not stop it spinning due to the horsepower of the stump grinder . Also this machine does not drive itself and has to be manually pulled or dragged into or out of position.
It also by nature of its design tend to dig itself in as it throws the waste underneath the machine body meaning after so long you have to drag it out of position and then rake out all the crud it produces ..
