George Foweraker
Hi Paul.
These were made from 2 boards each 12" x 3" x 8 feet.
First i marked of the boards into one foot x one foot and cut them into squares then marked a circle with a pair of deviders.
Cut out all the circles on bandsaw and put close to lathe.
I have a 3" faceplate with 4 points on it i then trap the blank between the four points and tailstop.
Then i turned the bottom and put a dovetail on.
I did this to all 16 blanks this means i dont have to change the spiked faceplate each time.The faceplate is held in the chuck so when i finished all the bottoms i simple take the faceplate out and the chuck is ready to use.
Then i mounted each blank in the chuck by the dovetail and turned the top.
The whole exercise actualy took me less tha two and a half hours i started at 12 o clock and they were finished at 2 20 i then roughed out 9 hollow forms by 9 0 clock.
All of my life i have worked on pricework or piecework and timing myself for olmost everything i do is a habit i cannot seem to break.
I am now mostly retired so i dont know why i do it.
Regards George
Regards George
