Molynoox
just a quick update on this point.that makes sense - I don't know a lot about planning fees - might they vary? If fixed then arguably they are already published so the client can see them anyway... if they can vary then it makes sense to not include them...
I think this is a common reaction - we all feel that if something doesn't go to plan - we would ideally like someone else to take responsibility - but ultimately there are too many unknowns in the planning and construction world, so it makes sense to recognise that - and if something unexpected happens (such as needing a bat survey) then that is an additional cost which is the client's to bear so it does make sense to allow for that - and to not have that option means they would have to add the cost in to a fixed quote - so you would pay it whether or not you need it...
from the research I have done about the fees for the application, and based on the fact the planning company have already executed 4 out of the 5 properties on the same street, I see no reason for them to be vague about the planning application fees. It is fixed and easily available on the planning portal website. Yes it could change if the council decide to make you go down 'full' planning route for example, but based on the fact that the previous 4 didn't do that and were just regular house owner applications, it would seem more pragmatic to me to provide the cost for this (£328) and add a proviso in the quote saying 'subject to change if council do not accept proposed application type' blah blah.
