Which saw... BandSaw?
Tsuki
New member
27 Sep 2024
Brighton UK
Hi, I am looking for some advice on a possible saw/bandsaw? I make jewellery and sculptural pieces from often 70+ 3-4mm thick wooden slats that I clamp together, carve, and join (rivet) I am exploring the potential of carving a block of wood and then cutting it into the slats (currently done with a handsaw). I have tried this on a small Proxxon table saw but had issues with the kerf, and when I reduce this, I lose the depth of cut. So, I thought of a band saw? I am unlikely to need a cut deeper than about 3-4” (sycamore, walnut, cherry, hawthorn, beech...) so I don't feel I need a big machine, but given the fine tolerance I work to, I need a very reliable fence/mitre fence which seems to come on bigger machines. I have looked at Record, BS300, Sabre300, and even Sabre 250 (I heard the fence is not good?). Ultimately, I need an accurate, reliable saw for relatively small work. I am not set on Record, and any advice would be gratefully received. Thank you, Patricia
My only experience of a small bandsaw is my old Elu bandsaw which I find excellent, sadly they are no longer available new but do come up for sale second hand quite regularly & usually at reasonable prices.
Also you are not limited to the fence the saw you buy comes with as it is not difficult to upgrade the fence.
Which ever saw you end up with I would recommend a meat & bone bandsaw blade, they have little or no set so leave a smoother finish than wood bandsaw blades & remove less material as the kerf is narrower, which from the sounds of what you are doing would be beneficial.
Thank you, that is really helpful advice regarding the blade. Would these be from a specialist (catering) stockist?
Thankyou P
Maybe one of these if you can find a late (direct drive) model with with the fence and mitre gauge…
https://machineatlas.com/machines/inca-euro-260/
That looks like a lovely little machincine and perfect for what I probably need, small and acurate, especially if I can get the micro adjust fence). Would spare parts (if needed) be an issue? Now I just need to find one. Thankyou
