sitefive":383i5ggo said:Clearly I did shoot myself in the foot by asking for a plaster suggestion when I haven't used this type of materials here and the one I have seen used by everyone else failed on me.
Anyway If anyone is looking to do the same ( to get decent finish on plasterboard without the mess/mastering of the ''proper plastering'' ) than the Gyproc Easi-Fill is really OK stuff for this, had to do 3 passes with sanding between each to get seamless finish and at a cost of around £14 for tape/ the amount of filling compound I used and about 4hours in total over 2days to get 18m2 room ready to be painted.
RobinBHM":q40lfq3w said:I think in this country tape and fill method of plasterboarding is used mostly commercially, IE in office partitioning.
It isnt really a method used domestically for housebuilding either new build or refurbishment / extensions.
I dont know if plasterboarding with square edge boards and skim coating actually takes any longer for a plasterer than tape and fill -probably not for a typical sized room in a house. I expect it would make a difference for office partitioning where jobs could easily be 1000's of square metres. Offices are often finished with wall paper -that massive wide stuff, so maybe a perfect finish isnt required.
One thing I really dont like is dot and dab plasterboarding -what a pain for any subsequent fitting work!
adidat":24cge15d said:I'm just sitting here trying to work out how some one uses 3 cubes of timber a month, and without any training???
Burning it?
RobinBHM":wkzftrg4 said:I think in this country tape and fill method of plasterboarding is used mostly commercially, IE in office partitioning.
that's the thing, I started on late sunday with nothing but freshly drywall lined room which I did earlier, yesterday (tuesday night) I had it all already painted and new laminate lied in and all finished ready to move furniture back in, in the same 2.5days I also had to rip up the floor and align the old crooked floorboards/ replace a couple meters of heating pipes and put up new radiator along with a few new electricity sockets and do some other bits&bobs.woodpig":19dx0f2b said:The other thing about using compound is no mixing and no mess. The guy opened the tub and then applied the compound with some kind of plastic spreader. After he finished he just wiped the spreader down put the lid on the tub and he was out the door.
woodpig":1ja3lmwa said:The other thing about using compound is no mixing and no mess. The guy opened the tub and then applied the compound with some kind of plastic spreader. After he finished he just wiped the spreader down put the lid on the tub and he was out the door.
adidat":egv65t0v said:I'm just sitting here trying to work out how some one uses 3 cubes of timber a month, and without any training???
Burning it?
woodpig":2cn0ultc said:The other thing about using compound is no mixing and no mess. The guy opened the tub and then applied the compound with some kind of plastic spreader. After he finished he just wiped the spreader down put the lid on the tub and he was out the door.
sitefive":2dcz9stq said:................along with a few new electricity sockets .............
Lons":6ep5poij said:RobinBHM":6ep5poij said:I think in this country tape and fill method of plasterboarding is used mostly commercially, IE in office partitioning.
It's a lot more common in houses from the mainstream builders that you might realise and not just low cost houses either Robin.
