I'm finishing a bench for our kitchen, which is intended to add a bit of seating + storage and hide two big radiators. Now that I've finished the carcass and am starting to put in the ply sheets I'm trying to find a good way to adapt the original design away from a straight back to a slightly angled back. The main problem this presents is that I've got to do some angled cutting to ensure the sheets can be fixed in place securely. This isn't too hard for the edges that sit against the frame, as my track saw can adapt to an angle, and I'm proficient enough to use a carpenter's bevel to ensure the angles work. But what the heck should I do with the corner in-between the two bench pieces where the two backs meet?
