I've always found this very handy, opens tins of any size and use the handle to tap lid in place. Very useful tool really use it often
https://www.ebay.co.uk/itm/173464452992
£1.50 on Amazon, but you have to buy 2+1 they are amazing things aren't they.
The old trick is to put the lid back on and then briefly turn the can upside down, so the paint forms a good seal inside. Avoid the paint going off from any tiny amount of air entering through the lid no longer fitting perfectly. Of course some will go off just from the air space in the can when it is not full, nothing you can easily do about that.They don't close properly after being opened a couple of times, which shortens the life expectancy of the contents - that's a bonus for the manufacturer, you have to buy it again.
I have put cling film on the surface of the paint before refitting the lid. Idea was to prevent a skin forming, seemed to work, removed film and paint underneath was ok.I read a tip that you should put clingfilm over the top of the tin before you put the lid on to help it seal and stop it sticking, I tried it but it didn't seem to help much.
Wilson's paints here in Exmouth used to give these away with tins of paint. Good marketing, I think, as they were embellished with Wilson's nameI have one of these. Exceedingly good value.
A wife and two daughters in the house, and not one wears tights, stockings or panty hose. I have to go buy muslin cloth if I want to strain liquids ....through a piece of women's tights. It's the cheapest fine filter material I've come across and works a treat.
I was given a tip many years ago to take a deep breath and breathe into the tin immediately before placing the lid back. Apparently more CO2 and less oxygen slows down the process of paint going off. Have always done this and it seems to work.The old trick is to put the lid back on and then briefly turn the can upside down, so the paint forms a good seal inside. Avoid the paint going off from any tiny amount of air entering through the lid no longer fitting perfectly. Of course some will go off just from the air space in the can when it is not full, nothing you can easily do about that.
I have one too, but I only ever find it when I don't need it...I have one of these. Exceedingly good value.
I always drop a silver teaspoon in the can, that way you don't even need to put the lid back on.I was given a tip many years ago to take a deep breath and breathe into the tin immediately before placing the lid back. Apparently more CO2 and less oxygen slows down the process of paint going off. Have always done this and it seems to work.
Looks good but the minimum order quantity is 5, which puts the price up to over £10!like the look of this one (never tried it though), bottle opener and nail puller included plus I assume the sticky out bit (technical term) on the side would allow you to get a really good twist (assuming the opener is strong enough)
https://www.amazon.co.uk/Coral-7351...ywords=paint+can+opener&qid=1674855231&sr=8-6
