Homeless Squirrel
Fill kettle just to amount needed for task.
Open/vent house in morning then close later for rest of day that way clear the damp claggy air replace with fresher air rather than hitting heat buttons feel warmer.
Turning shower off while washing don't really save as will still run after turn off as needs to cool element or burns out then needs to reheat when turn back on or "Cold" but can always turn down a bit but if sort your life out should be ready to go as soon as wet!
Washing run cooler and use likes of Vanish to clean togs!
Leds higher temps ie Daylight/cool white 6500k plus will give more light than Warm 5000k minus per watt.
But remember if block all the vents/airways etc etc will end up with a damp house and a damp house is never a warm one old house wasn't so bad as had lot's of wood and absorbent areas where as new/Junk builds don't so there often colder and end up damper not always are but feel more unfriendly so perceived more.
Jeans are one of the worst for colder times as hold damp! Around house wear tracksuit/joggie bottoms and decent slipper things ive these furry boots slippers Sobaka's(Russian for furry dog) toasty tootsies. =Warm feet =warmer person.
Another is looser tops rather than tight as loose gets a warmer air cushion.
