Phil Pascoe
I suspect the fence and "hedge" are mine - it was farm land and these bungalows were built before the ones behind us.
Jacob and his missus could stop by with their tents and give you a hand, you could discuss sharpening.Put an add in the wanted section, there must be some UKW members within a sensable range who would give up some hours to help someone out.
Why in whoever's name would you advise an invasive species as a solution to a problem???????Hottentot fig Carpobrotus Edulis, it spreads down slopes from top to bottom and requires no maintenance. It's classed as an invasive species though.
Beware the solution becomong the next problem.If you want a ground cover plant then look no further than this
https://hayloft.co.uk/product/gunnera-magellanica/pt15gum01-in21
I planted a small plant and it now covers everything so needs hard control but up on your mound it would grow well.
They are a good idea - in a small garden there are no invasive species which aren't controllable. They take over rapidly and cover bare ground, stabilising it and fertilising it as they die off. Cut them back and other stuff will grow better.Why in whoever's name would you advise an invasive species as a solution to a problem???????
Carrying stuff through no prob with a few dust sheets etc. Lots of trades are used to it, it's normal.They are also bloody expensive and everything has to be carried in and out through the bungalow. That's a no no.
Disregarding the native species that you mention which I don't consider invasive, I refer to the specific plant proposed by @Quercus.They are a good idea - in a small garden there are no invasive species which aren't controllable. They take over rapidly and cover bare ground, stabilising it and fertilising it as they die off. Cut them back and other stuff will grow better.
Nettles are brilliant in terms of reclaiming rough ground but there are plenty of other self setting "weeds" which are more attractive - around here it's valerian, sweet rocket, cornflowers, various ferns and many others. Then more cultivated varieties good for ground cover; michaelmas daisies, periwinkles, london pride, cranesbill and geranium varieties.
All in all a nice little project.
Never heard of it.Disregarding the native species that you mention which I don't consider invasive, I refer to the specific plant proposed by @Quercus.
As below:-
https://www.japaneseknotweedkillers.com/hottentot-fig
The LAST resort - you'll ne'er get rid of it again! It's a PIA in my bean patch.Bindweed.
Bamboo.Bindweed.
Grows up here in darkest Derbyshire. Vigorous and spreads into a shapeless bush after a few years even when trimmed, so to keep trim need replacing with rooted cuttings, which are very easy to growLavender grows like a weed around here, it's an idea.
Lavender needs the heat, we had loads when we lived near St Tropez ( neighbour had hectares of it, lavender products was his business ), up here ( similar climate to Phil but a bit warmer ) it has ( any varieties ) never really taken and spread.Does OK in pots, but is always spindly compared with the south.The mairie put Lavender in the flower beds, it didn't do nearly so well as the Rosemary.
