I made a start on a spindle extension for a replacement motor I burnt out. The original has a custom shaft, so I need to make an adapter. I wanted a real piston fit to reduce out of balance vibration. I was feeling rather smug having cut the receiving bore for the motor spindle to just 5 micron over size. With that tight tolerance I thought I’d better test the fit with the motor whilst it’s in the Chuck. Protective wooden board over the slides and the shaft slid in about half way and them became well a truly stuck. It was a lovely piston fit up to that point.
No prizes for everyone who worked out (it’s my theory at least) that the differential temperatures equalised and it became an interference fit. Took a lot of ‘oh dear me, silly me’ statements and a bit of sweat to get it off. Had to heat up the extension piece and be quick to get it off before the shaft of the motor caught up. Anyway, not so smug now as the bore is actually also tapered, I believe due to the heat build up when cutting, it’s narrower at the bottom of the hole than at the top by a few microns☹
