Also a more linear power adjustment curve, a more easily maintained arc and usually an 'anti-stick' feature to help you not stick the rod to the job.novocaine":2cvrnjly said:dickm":2cvrnjly said:They had one left in Ellon today, so I had a look, but couldn't see any real advantage over my current (sic!) setup of 100A Oxford and 140A Mig. Apart, that is, from being able to lift it and move it around without wrecking my back. But decided not to buy it.
Tell me - did I make the wrong decision? And if so, what are the killer advantages of inverter machines?
weight, duty cycle and ease of start.
Available online at this moment.phil.p":35jbe97f said:porker":35jbe97f said:Just a heads up Aldi also have a 140A inverter MMA welder at the moment. Ordered one today, haven't stick welded in a while and that was with an old buzz box.
https://www.aldi.co.uk/workzone-140-amp-inverter-welder/p/076597143942300
Sold out on line but in store today.
Thanks. Can see the weight and easy start advantages, but duty cycle? According to the box, the Aldi one will do 15% at full power. No idea what the Oxford will do, but I've never beaten it yet! And it will certainly outlast me, so no case for change! Must find something else to spend kids inheritance on.novocaine":141s7odt said:weight, duty cycle and ease of start.
stick with the buzzbox, if it dies think about getting a decent inverter, till then it isn't worth it.
oh, and you can scratch start tig with one too if you so desire.
dickm":17nph2mb said:Thanks. Can see the weight and easy start advantages, but duty cycle? According to the box, the Aldi one will do 15% at full power. No idea what the Oxford will do, but I've never beaten it yet! And it will certainly outlast me, so no case for change! Must find something else to spend kids inheritance on.novocaine":17nph2mb said:weight, duty cycle and ease of start.
DennisCA":1cenf800 said:I wouldn't give those cheapo things a second glance myself unless I was expecting to not weld more than a single 5kg packet for the rest of my life.
I started out with an old single phase transformer form the 80s, still works and welds fine, lacks fancy functions though and single phase rectification is not as nice as 3 phase, my dad has it now. Then I got a 300a TIG and stick machine very cheaply, both machines were Kemppi which is quality stuff. This one is built like a tank.
Which, of course, is exactly what the Oxford is - a tank half-full of oil with some thick copper wire in it!DennisCA":198jtmab said:This one is built like a tank.
