Derek Cohen (Perth Oz)
Here is a picture of my "waterstone board". The downside of using waterstones is that they can get messy with water slopping around. One of the tips I got from David Charlesworth's video was to use a spray water bottle (one of the ones made with gardening in mind) and mist the higher grit stones as needed. These stones are stored dry. The lower grit stones remain submerged in a Veritas Stone Pond, which is kept nearby.
Holding waterstones in place while honing was an issue before. I tried the "holders" that are sold specially for this purpose. They slide around. I tried router mats. Better - but they still slid around. So I have incorporated an adjustable clamp system into the waterstone board (for different size stones). I could have built in more than one, but I prefer just to use the one at a time.
The other issue is maintaining flat waterstones. I use King waterstones (800, 1200, 8000) and these respond well to 220 grit drywall mesh. The waterstone board incorporates this to the left of the honing area, with a clamp that holds the mesh at one end - this is sufficient to hold it flat (especially as it is also held down with surface tension when wet), and one end may be lifted to clean underneath or sop up excess water.
The waterstone board's surface is flat (carefully checked), and waterproof ( covered in laminate). It is solid and heavy (made from 65 mm chipboard). The front incorporates a stop so that it can be held on a benchtop in the same way as, for example, a shooting board.
http://www.woodworkforums.ubeaut.com.au/attachment.php?attachmentid=8843
http://www.woodworkforums.ubeaut.com.au/attachment.php?attachmentid=8844
http://www.woodworkforums.ubeaut.com.au/attachment.php?attachmentid=8845
My wife loves me again as I no longer need to use the laundry to sharpen blades.
Regards from Perth
Derek
Regards from Perth
Derek
