wadkin RS lathe restoration
Thanks Jim, the power feed came with the EQ spindle moulder. I think it needs some new wheels, its also a pig to set up
The lathe is looking fantastic, I particularly like the refurbished black and gold plates, very smart
Hi Merlin / Wallace, at long last I have found out how to upload photos, so here are some of the RS for you to enjoy. Showing my indexing arrangement and the router attachment and a special drive and special tail stock pieces, and by the way the large faceplate is 6' 9" diameter, hope they are interest to you, thanks a lot Stan.
    99.1 KB
    105.8 KB
    91.4 KB
    155.2 KB
    139.7 KB
    130.4 KB
    131.3 KB
    127.8 KB
Hello Stan,
Looks fantastic - an RS doing what it does best.
The indexing set up looks very good .... would the maker of such a thing be interested in making another?
Merlin
Hello Merlin
Thanks for your kind words. In answer to your question NO I am the maker and also a septuagenarian who is running out of time in life. A short history of the lathe. it was 8" centre height I lowered the bed on the headstock and had a block cast to raise the tailstock and made a new leg as I was joining two together. the piece of wood in the lathe was actually a tree trunk just for testing the lathe I made a new fitting for the headstock drive and tailstock so it couldn't come out then I made the router bracket (that was easy) but I had to make a dovetailed stop for the cross slide because it kept altering it's self. The indexing plunger I picked up at an auto-jumble and the division wheel with circles of 24,20,9 & 7 holes I made on a Colchester student lathe. I also made a cap to fit the spindle so as to remove the drive centre easily. I also made patterns and had some faceplates cast. PS I don't use the lathe wood turning lathes bl---- frighten me. Cheers Stan
