wadkin RS lathe restoration
hi, Wallace how did you date the lathe? I have one machine no rs585 test no 18559 which looks older than yours. the top of the headstock is curved and the name is cast under the top window, the only other difference I can see is the top pulley which has no grub screws. I have had every nut & bolt to bits on this lathe and also fitted an indexing arrangement and painted it wadkin green. I don't think I am too far away from you in Bd Castle ? keep up the good work regards Stan
Hello Stan,
I restored mine last year - it is an RS 10, the machine number is RS 579 and the test number is 18327.
I phoned up Daltons and was told that it was manufactured in 1942, yours was probably in the factory at the same time !
Yours sounds like the same with the window and the casting.
Cheers, Merlin
Thanks for that Merlin, we have a lot of Wadkin machines but I try to avoid Dalton's as I have never found them very helpful. Back to the lathe, I actually joined the bed of another RS lathe together, we can now turn 10' - 7" by 17" dia. The spare head stock we have fixed a 6' - 9" dia. face plate controlled by an inverter drive. If I can persuade my son to take some photographs and upload them for me you will see what I have done, I am no good at modern technology. regards Stan
Hi Stan this is the earliest version of the RS I have come across. It does not have a brake or the pin that locks the spindle on the outboard side. To lock the spindle you have to do it through the window. The tailstock is different in a few ways, the motor is different as well.
A friend has a catalogue dating from 1936 and it is identical to my lathe.
Your lathe is quite early because of the window, depending on which type of machine tag you have you might be able to date yours. If it is a tin tag then you cant get the date, if its a brass cast tag then it has the year on it. If you look at this PK tag the machine serial number, the first 2 digits represent the year of manufacture, so 1955.
So two lathes joined, have you turned anything to its capacity?
Looking beautiful, lovely to see these old machines restored to better than new
I some how managed to drop the handle of the banjo and it broke (homer) To fix it I drilled and tapped each bit and then welded
This time I used my new face shield my wife bought me 12 months ago, so no burnt brow. I'm not the best welder but it ground down pretty well with just a couple of pin holes.
I thought I'd strip the motor, I tested it before and it is good.
The pulley support had not been taken off before and it was full of pretty clean grease.
I tried a puller on the pulleys and it moved easily and then stopped when it got to a collar on the shaft, it wouldn't budge so I looked closer.
The collar is pinned through the shaft.
dickm":2n120bi0 said:
Reassuring to know that someone who does beautiful restorations is nearly as cr*p at welding as I am! :D
A welder told me you don't need to be good with the torch, you need to be good with the grinder :lol:
The motor came to bits pretty easy.
I think this motor was originally an open motor which was adapted to be used for the lathe. The later lathes had an enclosed motor with fins.
Hoffman bearings
I have been spending a lot of time doing the prep on the castings before giving a coat of zinc primer.
The main headstock is taking a lot of work, it has a lot of dings and the casting are pretty rough
This is how I do the tags,
After cleaning with a brass wire brush, I sanded and then polished
I then spray with a black paint from a rattle can. It takes a few coats to fill the background
A little more progress, I primed the headstock
This helps to highlight any imperfections
Then I go round with more bodge
The motor got a coat of black enamel along with some other bits for contrast
wallace":1ziw71i1 said:
This nice box of electrickery got delivered today, so now the lathe will run from a domestic supply
Are these easy to wire in? I have a 3ph motor on my drill which I need to get one of these for.
They are really easy just Live Neutral earth in and three wires and earth out. Plug it in and it configures itself to the motor
I have been doing a lot of painting in the past few days, because I use enamel you can build the coats up quite quickly. By the time I've finished spraying I can go back to the beginning to give another coat. When done I left everything for two days and then went over again.
The bed was is really nice condition with nearly all of its original filler intact. This is the first wadkin I've found which was originally black
It has the number 115 stamped at the end of the bed which corresponds to the machine number on the tag
Don't know if I missed it in other threads, but what kind of paint are you using here? I always thought enamel paints had to be brushed on?
Thanks, loving the restoration threads.
