That's if you have markings on them, (if you're referring to the press on plastic like on Fender or whoever else)
I wouldn't have a clue if the actual pot is suitable, and just buy one along with the rest of the buttons.
Are you saying the actual pots are unsuitable?
Tom
3 phase fractional hp motors can be run directly from 240v single phase with the aid of a suitably sized capacitor, although there will no doubt be a reduction in power.
Just a quick update managed to get the motor working with cheap invertek E2 inverter off ebay, very pleased to be honest, just mocked it up at present with some fine tuning to do
Whilst writing I found the following information all on here and thought I might list it all in one place
Bearings sizes and types
Head stock end LJ.1-1/8.2RS.EU the cover will need to be removed on oiling side
Tail stock end NLJ1.1-1/8
I've yet to fit these, I brought them cheaply on ebay
Just a little update had to buy a new motor as existing would not work that well, I went with a dual voltage 3 phase 1 hp as I had a inverter for the same works well
I gave it a quick rub down and sprayed it with a coat of clear lacquer
Next thing to to put it on some casters to enable movement and also raise it as a little low for me + a set of crown centres
