Simon, I'll post some links up here tomorrow (my bookmarks for these things are at work).
Mike - Thats not bad for a tele neck assuming it's a fender one. You would be hard-pressed to get a good aftermarket (warmoth) for any less - of course, it's not overly difficult for you to make your own! Or I could always help you out in that area if you're interested.
Mailee - The workshop build was quite a long time ago now, which is quite surprising as the time has gone by quite quickly, so thanks mainly to chaps like yourself and others on this forum, I feel I've improved on the whole woodworking malarky a little, although to be fair, I did have a little experience of guitar building before getting into the woodworking thing, so I find doing this work is a lot more in my comfort zone than furniture/workshops etc..
On to todays progress.
Today's work has been the most laborious, its not a task that can be rushed and is one instance where a dedicated tool is probably worth the cost, i'm talking about fret 'crowning'.
Yesterday, I left with the frets levelled, but flat on top, so crowning is needed to restore the rounded shape, I decided against an expensive dedicated file for the job and ground a 'safe' edge on a triangle file, this worked to a degree, but was very slow.
The pics:
Safe edge ground on a triangle file
Board taped up ready to file the crown back into the frets
You can see the 'triangle' shape on each side of the fret, the flat top starting to disapear, I kept going until there was only a small slither of flat on top of each fret.
Using a stew-mac fret dresser, I filed the shape I wanted in the green stick, a belt of abrasive is then installed and rubbed up and down the fret to polish away the deep filing scratches, it comes with a number of abrasives, and you just work up the grits, removing each successive scratch pattern, this also helps restore the shape of the fret.
About half-way through the abrasive dressing processing - you can now see how the fret has lost it's flat top and has a nice round profile.
After the dressing, the frets are rubbed with various grades of steel wool until they shine! It's hard to photograph how shiny these are, but they are like mirrors now, should be nice to play on!
I didn't get as much done tonight as I hoped, just this process of crowning, dressing and polishing took over 2 and a half hours! Much longer than I anticpated, mostly due to the inadequate file, I shall be investing in a dedicated crown file for future work.
But, thats the hard-work now all finished!! I just have small jobs left now, such as drilling the holes for the bridge mountings, and the machine-heads, then I can put on the final finish, add the electrics and then it's a case of perfoming the final setup of the action, setting the nut, and testing for intonation - then, it's metal time!!
If I can get hold of a video camera, I'll try and upload a vid and record some riffs.
