Biscuit jointing ?
waterworks
16 Oct 2016
Bletchley
I have a Rexon biscuit jointer I've never used lurking at the back of the tool cupboard and now a job has come up for it , the blade is 100mm diameter and the tips measure 3.8mm , what size biscuits do I need for it ?
Standard Biscuits vary in width and length, not thickness. There should be an adjustment for the depth of cut on the machine, usually three options, and you buy the biscuits to suit the depth of cut which in turn will depend on what you're jointing.
Something like this:
That’s on a fairly generic Erbauer. Set to size 20.
Biscuits are OK, I use them a lot, BUT they don't "penetrate" very far into the boards being joined - they're more for "location/alignment" than "strength" - for something like a worktop bench I'd consider dowels* with a bit more depth into the boards.
*cheap drilling jigs are available
I will be jointing 200 x 50 boards edge to edge to make a workbench top.
Then why use biscuits at all? Alignment would be the only reason as they won't add anymore strength to a long grain to long grain joint. If you are going to surface the top then just be careful with the glue up and only glue a few at a time, no wider than your thcknesser. Take a final thickness pass to clean them up and then you only have to get one or two joints perfect to complete the glue up. If you feel you must use the biscuits for alignment the smallest are enough and only a few down the length.
Biscuits originated for assembly of cabinets from sheet stock to replace dado/housed joints to simplify and speed up the fabrication. They are a strong joint when used that way.
It's probably made with a 3.8 tolerance to give a snug fit for the biscuit. Try one for size. If it's too tight heat the biscuits for 20 seconds in a microwave and you should be ok. Just out of interest Lamello are the only company who make interchangeable biscuit blades. A 3mm blade is available for thin boards.
So you need 20s.
The Lamello biscuit jointer manual on my lap agrees.
Set for a size 20 biscuit, the machine cuts snug grooves 12.3mm deep at the centre.
The size 20 biscuits are 56x23x4mm. So you have about 0.8mm space around the long edges of the biscuit to let the glue flow.
50mm is a good thickness. I don't think you need biscuits, but if you want to go that route, set the depth to whatever biscuits you have, you're only using them for alignment. The glue will hold them either way if they have good, square mating faces.
Try some practice cuts and see what the fit of the biscuits is like
In my experience biscuit jointers vary a lot, some have a slight wobble and create a loose biscuit fit.
No egg-sucking intended, but also ensure you reference cutting of the grooves from the same face of each board.
I'm aware of at least one member on here who wasn't concentrating once and norzed it up.....correctable, but a pain.
I recall an article in fine woodworking call " build a housefull of doors" it used 4 biscuits in each corner! Whwn biscuits are mentioned i always think " wonder if thise doors are still ok?"
He used t and g infills and no mid rail....... it was 20 years ago.
I made an Oak screen door using biscuits for my front door. It slammed (I think a screen door should slam shut, doesn't sound right if it doesn't) every time I went out or in for almost 25 years. None of the joints showed any signs of letting go when I took it down and moved here. Biscuits are a lot stronger than you think.
I don't understand what seems to be a dismissal of biscuits on different posts from more than a few contributors over time. I've used biscuits for decades and have found them to be very useful and fast for alignment purposes - why fiddle with face alignment when the jointer does it for you - glue is slippery.....
I'm with the Inspector/Pete.
Long lengths and multiple boards - then certainly biscuits can certainly help with alignment. Shorter lengths much less so in fact sometimes it is easier to hit with a soft mallet to line up and then add cauls and clamps for horizontal alignment. Biscuits add very very little/zero strength to a long grain joint - the joint will not break at the glue joint.
Write your reply...
