the great waldo
I've been making my own pickups for about 10 years now and it's not rocket science to make them, however getting them to sound as you want them to is like making an acoustic guitar and knowing what it's going to sound like at the end, if you cna do that then buy some lottery tickets. Wiring guitars is not difficult but there can be unseen traps (poor components dry joints etc) that can lose you a lot of time in troubleshooting. By the way what's cheap wire?No updates at this point - we're in "the slows" where I sit down and run a series of french polish or fix small issues of finish near binding that's hard to french polish. I hope to get the remaining holes drilled for the knobs and switches, which on nice carved top guitars, follow the contour of the carve.
So, my carve is a bit flat at the belly where the knobs will be, but it's still not flat and I work freehand with driling (same with the bridge and tailpiece holes - drilled by "visual jig" (using squares in two directions as reference and then checking visually with the drill. It's just safer for me with more feel and ability to circle around the guitar and make sure everything is relatively lined up in ever direction. )
I don't much care for wiring guitars - it's not like you can't do it without knowing much about soldering, there are patterns everywhere. I just think it's a pain because I like to know everything about every component (which usually results in me making *everything*, and I don't know much about the internals of audio pots. I'm open to making pickups in the future, but not quick and cheap from kits with plastic bobbins or cheap wire.
Andrew
