Steve Maskery
Do not touch those bolts!!!!!!
They control the tracking of the bottom wheel and nothing you have said suggests that that is a problem. They are factory set and should not be altered unless absolutely necessary. Plus, making the shaft more central will make your problem worse, not better. And if you alter the East-West pair your blade will just be shrugged off.
I repeat, don't touch those bolts.
S
S
