Hmm I put the 3/8th Tuffsaws M42 blade on today I could have wound the tension further but a quick lateral test told me it was ok. So how much lateral movement do you have with the guides at the full 12 inch cut. I had about 1/4 inch
will check tomorrow pac, may do a couple of wee videos alsoPAC1":6cmhio19 said:Hmm I put the 3/8th Tuffsaws M42 blade on today I could have wound the tension further but a quick lateral test told me it was ok. So how much lateral movement do you have with the guides at the full 12 inch cut. I had about 1/4 inch
Steve in my case that would explain the difference in tensioning the blade, Record supplied a 3/8" blade, the blades I bought from Ian are 3/4", both blades are approximately the same thickness. I am not complaining about the blades supplied by Ian, it cuts straight and true although the tensioning is at its maximum, Ian supplied exactly what I asked for i.e. A blade 133" long. I am not concerned about the tensioning as I slacken the blade off after use with the 'cam action tensioner'Steve Maskery":1g9n7sl9 said:Are you comparing like with like? I.e. width and thickness as well as length?
The general rule is that the more steel there is in the blade the greater must be the tension.So wider thicker blades will need more tension, even if they are the same length.
S
CHJ":2nnbs31r said:How is the lower wheel centred and adjusted for parallel running, can it be lowered, thereby increasing the between centres distance a few millimetres, by adjusting upper and lower centralising bolts for instance as it can on some designs.
