Trying to find leak behind wall
JamiePattison
19 Apr 2022
Earth
Hey guys
Thanks to everyone for helping me in the past.
Cutting a long story short I could smell some plaster/wet paint in one of the rooms.
Turns out the shower waste pipe leads into this room which is sitting behind the wall in this room. Eventually i eliminated other areas and then I turned on the shower and couple of minutes later I heard some drops behind the wall
My question now is I have an endoscope camera and tried putting it down holes around the bathroom to see if I could see any leaks from these pipes but nothing could be seen of interest.
The wall that protrudes out is in the downstairs room and the room above it, this wall must have a waste pipe going from the shower and behind this wall.
I think I could drill a hole and put in the endoscope camera to look around but I don't wanna create a new problem either e.g. have a few holes which don't help me narrow down where about in the wall the issue is with the pipe or worst case scenario drill a hole into the pipe.
Can anyone share any ideas of where an appropriate hole should be made to narrow down the source of the water drip on the pipe, any other ideas? Or simply is it time to call in a professional?
Shower waste pipe or shower waste itself, either way you will need a much larger hole to repair this than that needed for the scope. Is the pipe within a boxed in section ? If so you will need to remove the decor to see if there is a panel that can be removed wich might be better than drilling holes to find a leak that will need fixing anyway.
Is a shower waste pipe. The pipe leads from the shower then all the way downstairs.
I can hear drops downstairs when the shower is in use.
What I'm trying to ask is although the hole to repair the pipe would be much bigger, I'm trying to find a starting spot to look and see where around the pipe may need fixing which is hidden behind the wall.
So I think the room upstairs needs a hole somewhere so I can try and view where the leak is. The wall is 8 feet high so I don't know where about I could first drill a small hole and to see what's behind the wall to give me a starting point to?
Overall what I'm attempting to avoid is drilling 10 holes only to see where the leak is coming from. Once I know and if I feel I can silicone it or something I can then cut a bigger hole, finally repair any holes and the cut made.
I don't know if there is a standard area on the wall where I could drill a hole leading me to some joints or something (me taking a wild guess).
I hope this made some sense as I'm not a plumber but just someone trying to see if I can fix this before calling out a professional.
In my experience leaks normally appear at joints and the most common place for joints is at changes of direction although the shower outlet is often a problem. I would start at these places although finding a leak is often a problem as water often appears some distance from the leak.
Good luck.
Good luck.
Based on that would you think the problem could be on the same floor as the shower? As I was thinking maybe the room under the shower maybe a starting point?
Have you ruled out the water feeds to the shower? It is possible when the water is turned on some leaking occurs after the valve on the way to or at the shower head.
It may be anywhere and where you hear the drip may not be where the leak is. I would try at the shower first and if it is not try to find a joint somewhere in the middle to try and narrow the area of the leak.
Hearing water in one location doesn’t mean that’s where it’s leaking. Water will often follow the underside of other pipes and then drip onto another pipe or joist and do the same again . Yep call in the professionals - why don’t you claim of your insurance and let them deal with it . The leak itself could be fairly minor but getting access to it is a completely different story. If you start drilling holes looking for it you could invalidate your claim . Leave it to uout insurance ..
Below are picks from such a job leaking onto kitchen ceiling but shower tray was as good as welded to the floor / cust had no insurance so as there was no access under the shower tray and the ceiling below had been recently cladded they opted to replace the entire bathroom.. turns out there was also several leaks from the hot and cold supplies +all the waste pipes were blocked ..
    2 MB
    2.1 MB
    2 MB
    1.9 MB
Recently had to find a leak in a friends roof- the drip itself is definitely no indicator of where the actual leak is- in her case, the actual leak (blocked gutter) was on the opposite side of the roof ridge from the actual leak!!!!
Her roof has 3 different levels of gutter- the highest had a small blockage at one end (away from the downpipe lol)- that caused water to spill back into the roof cavity and run along beams, changing direction several times, before dripping out her bedroom light fitting!!!
It had traveled almost 15m by this point away from the actual source!!!
I was amazed that it could be so far from where it finally appeared- I spent several hours checking and rechecking the roof over her bedroom looking for it- both visually and with a hose- it wasn't until it appeared after a weeks worth of rain I climbed up into the roof cavity and traced it back to its source... following the wet beams right across to the far side of the house!!!!
The leak was at the front right of her house, the source was literally as far away as it was possible to get, at the back left!!!
