You could be describing me there @D_W , I'm still standing but definately droop in the middle
Neither moniker would in any way give me the hump (sic). Anyway, the evidence of my lackadaisical or intermittent approach to posting is in my Message count. I see that over roughly seventeen years I've managed to spout my ill-informed and ill-considered waffle in less than 2,400 messages, an average of <140 per year, or about an average of ~2.7 messages per week. I'm fairly sure I've noticed some newly registered forum participants post that number of messages or maybe more in just a few weeks or months, then it's as if they burn out and disparoo forever. So, intermittent, slowish and steady seems to have kept me reasonably engaged for all that time, and I'm aware of quite a number of contributors that have come and gone, and some that come back again. Slainte.Moderators, please change richard's subtitle from established member to "Post Camel" or "Forum Camel"!
Yes, to show I intended to use the word or phrasing, but not there to indicate a previous misuse quoted verbatim. It was used in this case because 'give me the hump' is a quite common alternative means of expressing upset caused. It crossed my mind when typing that you, being American, may not be familiar with this quite common British usage, meaning you might need to think a bit to get the joke with its reference back to camels that you'd introduced - perhaps you'd have got the wee joke easier if I'd typed (pun intended) instead of (sic).what's the SIC for, hump?
I think John PW's plane was either a tooly's experiment gone wrong, or deliberately converted into a picturesque door stop. One clue is the added door knob screwed on which surely be ripped off in no time under normal use.My humble apologies for interrupting the general conversation, but I'd like to ask a question, if I may.
Dr W posted pictures of a fairly standard wooden try plane with a gob of lead stuffed up it's nose. A few posts later, John PW posted pictures of an unusual looking shortish wooden plane with a very high angle double iron, a ludicrously tight escapement and stuffed with gobs of lead front and back. My personal suspicion is that the latter plane wouldn't function very well, if at all; but, nonetheless, somebody went to some trouble making it, including the added lead.
Erm - I'm curious, and don't know why - what's the added lead there for? More weight, presumably - but why?
Heavier doorstop?Why the added lead, though?
PS. I was about to post this, and I happened to look up and spotted your posting numbers. I'd say you're, well ... er, prolific, and over a relatively short time too, i.e., 6,000+ messages in less than five years! That's going it a bit I'd say, ha ha.
I'm going to chuck in that I dont think its anything to do with weight as the amount looks to be a couple of grams worth. I think its maybe more to do with a split/crack or hole to stop it spreading.Why the added lead, though?
I see the logic, but Dr W's try plane seems not to have any cracks of substance, and JohnPW's plane shows minor cracks at the toe end, but not where the lead is.I'm going to chuck in that I dont think its anything to do with weight as the amount looks to be a couple of grams worth. I think its maybe more to do with a split/crack or hole to stop it spreading.
Could be wrong, frequently am.
When posting I only noticed the two parallel holes on top. The larger hole now i see it I suspect was for adjusting the plane blade.I see the logic, but Dr W's try plane seems not to have any cracks of substance, and JohnPW's plane shows minor cracks at the toe end, but not where the lead is.
That said, since we don't have a definite reason, might not be wise to rule the idea out completely.
