raffo
my krenov plane has a mouth that's 1/4000ths of an inch, it's great for figured woods and exotics, I think it does make a difference and beg to differ.
That's 0.00635 mm, that doesn't sound right.
I didn't say it would be any good. It was a suggestion based on all the claptrap about needing super high angles and thin mouths and lots of weight to work gnarly woods in the various woodworking media at the turn of the century. To me basically to help sell all the new designer planes with foot thick irons etc because a Bailey design couldn't plane exotics even though the evidence sitting in museums said otherwise.
I agree about the retro planes just being a gimmick, largely copying long abandoned dud ideas like Norris adjusters, thick blades, brass knobs all over.I didn't say it would be any good. It was a suggestion based on all the claptrap about needing super high angles and thin mouths and lots of weight to work gnarly woods in the various woodworking media at the turn of the century. To me basically to help sell all the new designer planes with foot thick irons etc because a Bailey design couldn't plane exotics even though the evidence sitting in museums said otherwise.
That's how I understand it. There are infill smoothers, less common are infill panel planes (which are smoothers for panels), and even less common infill jointers - uncommon because they cost the earth when new and you need to be built like a prop forward to get them to the work. There are infill shoulder planes, chariot planes, mitre planes and thumb planes - but NO infill jack or try planes (unless someone built one by mistake).Surely those fancy infill planes were for finishing not preparing sawn timber ?
But have to say that fine adjustment of cap iron is effective with difficult grain for the simple reason that the closer the cap iron, the steeper the planing angle, the more it becomes a scraper rather than a planer.
But it's much easier to use (and sharpen) a scraper such as the cheap Stanley 80, so why waste your cash?
It works both ways - a fine set plane won't work on easy wood you have to set the cap back a bit to get good thick shavings.
Anyone preparing timber with an infill (unless it's very dense, hard, exotic timber, in which case you probably won't be preparing a lot of it) has missed the point.
The trouble is, today's Bailey planes do not conform to the design Bailey submitted to the US patent office. The original had the lever cap pressing the blade via the cap iron, onto the frog at 3 points, not todays 2. I've not seen a cap iron like Bailey's original even in the 1950's, they are all bent far too much; this was the reason behind the stayset 2 piece cap iron, or the Millers Falls 2 piece lever cap.
The 2 piece cap iron is not a precision item and can't easily be set close enough to the cutting edge when this is needed for your smoother. A thin blade and a flat cap iron works well with the Millers falls lever cap (3 point pressure).
Of course, historically Stanleys may have been closer to the original patent, or maybe the apprentice was just given the scraper...
The reluctance to pay attention to the importance of mating these two surfaces is why people mainly set the cap iron away from the cutting edge by an sixteenth of an inch or more.
Yes, in your dreams. It can happen if everything is freshly set up with the chip breaker back a bit to reduce the curl, but particularly if you have the right bit of wood to work on - you need to use what Rob Cosman uses, or as per those Japanese planing demos.The principals work with wooden planes. When the cap iron or "chip breaker" as my uncle used to call it is set correctly, wooden planes produce a straight shaving which comes out like a long ribbon of wood.
You need to bend it down a touch.Guilty, yer honour. At least, on the cheap Bailey-copy I found at the bottom of a toolbox I bought. I just can't get that gap to close no matter how much I lap the cap iron. I really should have another go at it.
Exactly my point. Why go to the trouble and difficulty of adapting your plane to work like a scraper instead of simply using a scraper?..... Set for troublesome stuff, the actual cutting geometry round the blade edge is rather like a scraper with the addition of a close mouth.
Bend it back..... they are all bent far too much;
Yes I agree, but with a bit of careful fiddling a normal cap iron will do just as well.this was the reason behind the stayset 2 piece cap iron, or the Millers Falls 2 piece lever cap.
If you are trying to get rid a belly when paired with your iron, get a small strip or square of abrasive narrower than the width of the cap iron and hollow the middle/bump away on the underside.Guilty, yer honour. At least, on the cheap Bailey-copy I found at the bottom of a toolbox I bought. I just can't get that gap to close no matter how much I lap the cap iron. I really should have another go at it.
