Eric The Viking
- Joined
- 19 Jan 2010
- Messages
- 6,599
- Reaction score
- 76
That pic doesn't look very nice, in particular the tearing you're getting on top. It looks as though the rubber strip has been cut in too far by the other blade, and that it isn't sitting snugly down on the material. The rubber should meet the wood everywhere along the cut.
If you replace the blade, whatever you get needs to be exactly the same spec. That means same kerf, same tooth rake, same plate thickness (kerf and plate thickness are really important), and same diameter. You can vary the tooth count, obviously.
I think I can see where you might have paused or stuck slightly going over the joint in the track. That's either because:
- The joining pieces aren't aligning the track correctly,
- The track is dished or otherwise bent (mine are very slightly dished and it can be a pain),
- The two rail extrusions aren't identical (my 3m rail is a very,very slightly different shape to the shorter rails, which are several years older: I assume the die had become worn, and it means they don't ever join nicely),
- You've got the "sloppiness adjusters" (saw on rail) done up too tight.
At least those would be the reasons on my saw! It also looks like it doesn't have the tiny amount of toe-in that's helpful (you shouldn't see a complete arc, as the back of the blade shouldn't touch the cut surface), but I've no idea how to set that, and it's best left alone if there are no instructions for doing it.
HTH,
E.
HTH,
E.
