You've been busy this week then Paul, bout time you found a use for that Zebrano you keep buying, got rid of some of the Pent up
frustration that has been building the last couple of weeks I guess :lol: The Yew ones certainly look attractive when you can get the colour blend across the blank.
Addictive aren't they, cut up a load more blanks in Yew and coloured Ash myself yesterday to fill an order over and above the home consumption ones that seem to be getting allocated as quick as I can produce them.
Been doing some in green cherry, cut them a little larger 18-20mm to allow for warping whilst drying, some long grain, hardly moved, some cross grain moved quite a lot but still well within usable tolerance, considerable difference in appearance between the two cuts when finished, the cross grain results in a sheen like reflection that changes with the light when you turn them adds interest into what could be a bland wood at this size.
Had a rogue tube length in a click kit I had from axminster, 2mm shorter than it should be, might know I did not cotton on until it was assembled and the refill would not retract far enough #-o guess who will check all kits from now on just in case.
