OK, should preface this with nearshore tidal is inefficient. basically the energy is to dispersed to collect efficiently. We see small scale tests that give great efficiency but it's simply not directly scalable.
other tidal generation (estuary) is better but still not great, the strangford lough turbine is a good example but it is very much a local generator (1500 homes, when it works) and scaling of the system is all but impossible, it blocks about a 1/4 of the water way and needs to be in the deepest section of the inlet, adding more across the inlet won't work but an option to run them inline would, however, we have no idea on the impact of wildlife from doing that and each turbine would see less motive power due to the ones in front but also in dispersal of energy across a wider area.
in the UK we could maybe use the tech in 3-4 different locations but that won't happen due to the impact on shipping (they aren't going to do in in the Humber, it could work on the Seven but unlikely to work on the Mersey) . it's also very cyclical, with peak generation only achievable during extreme high tide, which means efficiency is affected simply because we can't turn it at it's peak output.
offshore tidal is a different thing again and as said with emerging tech of floating turbines we may start to see combined units, but distribution and tie back is going to become a challenge. current technology isn't there for tidal energy and investment in it is somewhat lacking (chicken and egg).
