DBT85
Nick, there's a thread in General about Davies Timber, someone asking for experience to build up a guide.
Wow. I paid less than that for the sawn beech for my bench! There is probably slightly less volume than what you have though.DBT85":ydikrhgo said:Finally getting around to getting my wood ordered for my own bench. Need to make some quick and easy saw horses too so will just go with some of Mattias' ones for the time being, made form CLS as its cheap and more than adequate.
Like yourself I've had to wiggle with Mr Sellers metric measurements as they just don;t match timber available and it seems daft to cut things down where there is no need.
In the end I've gone for
4x 50x75x3.6m for the top (will use all 8 lengths from these, making the top 45mm wider)
1x 25x150x3.6m for the wellboard (a smidge thinner than spec but didn't fancy going thicker)
2x 50x150x3.6m for the aprons. (Won't be planing these down to 40mm like you did!)
1x 50x150x3.6m for the rails
1x 75x100x4.2m for the legs
1x 50x100x2.4 for the bearers
With that lot, some CLS for 2 sawhorses and a 18mm sheet of Elliotis pine ply, plus delivery it came to £240. £30 for delivery seemed a bit steep as Avon Timber will do it for nowt and they have to come over from Coventry, but with me only just getting my new wheels and it costing at least a tenner in fuel to get to Davies, plus my time on top I figured sod it, Also transporting a sheet of ply in the car would have been fun
Seems like so long ago I wanted to start this!
To be fair, about £45 is timber for other stuff and £36 was delivery. So £159 for a load of PAR redwood for the bench and there will be a little left.Bodgers":2y2xwd62 said:Wow. I paid less than that for the sawn beech for my bench! There is probably slightly less volume than what you have though.
Sent from my MI 3W using Tapatalk
DBT85":16efpjpf said:Finally getting around to getting my wood ordered for my own bench.
Like yourself I've had to wiggle with Mr Sellers metric measurements as they just don't match timber available and it seems daft to cut things down where there is no need.
NickN":hv2sqrxh said:Excellent news! If I'd known I would be recently getting a planer-thicknesser before I started this project I would have made my order a little bit different, but not to worry, where I have had to reduce thickness it's been very good hand planing practice!
Davies Timber prices seem to be a lot better than Avon Timber too, certainly for sheet goods anyway, so it makes up for the delivery price on a large order.
Next up is to groove the rear of the rear apron, then rebate the wellboard to fit both grooves.
