So you'd impose ULEZ over the whole country equally? Surely it'd make more sense to start with the worst areas and work out from there?
Have a look at the map in this article, though I guess you think the figures are all made up.
Ulez key to tackling ‘unacceptably high’ child illness and death, doctors say
Don't be silly.
I've already said that the results in the ULEZ ref health are correct and accurate, you obviously don't fully read responses before you jump to conclusions.
I'll repeat it again...
"I agree that evidence to prove ULEZ is accurate to the data, I even agree its robust enough to prove the impact of the ULEZ. What I don't agree with is that just extending the ULEZ, while good for that area, the result is its not cleaning up the environment, just relocating and redistributing emissions"
So please dont be so ignorant as to rehash your same verbal diatribe without understanding or acknowledging the actual agreement I gave to you.
What I said is that a different approach to ULEZ is needed so as not to push particulate pollutants onto others.
My approach is to eliminate particulate matter that causes these illness, not just relocate it.
Surely better health for all should be the target, not solving just one area, while building up issues in another area.
ULEZ do NOT reduce the overall particulate emissions, they just remove the issue in one area, albeit significantly, however it does not reduce the overall particulate emissions into the planets atmosphere.
I'll say it again unless you missed it. Yes ULEZ affect local issues, they do NOT affect the overall particulate levels significantly in the atmospheric strata.
To have an amospheric change and EFFECT, NEEDS WIDE SCALE CHANGES, as I indicated as a possible scenario going forward.
I never once said abolish or abandon, or extend the ULEZ, I just said there is another option that we could use that would benefit everyone AND the environment. Reducing particulate emissions is the only long term solution, not the transference from one area or from local to regional emissions, as is the case for EV's unless they are purely produced and run on green energy, the result of there pollution is not local, they actual help in ULEZ, what the evidence shows is that overall their emissions through manufacture, extraction of limited rare earth elements and the transportation of materials and batteries across continents are as harmful, but not on a local basis but on a worldwide environmental impact basis.
Again another case of we're fine in the city, bugger what happens elsewhere.
We desperately need an approach to reduce emissions, not just shift them to other countries.
