wizer":1bayryi0 said:...after I filled the skip up with all the packaging....
Steve Maskery":1wcbcp1p said:Dom,
Why? If the table is right forward then so is the operator, surely? It looks fine where it is to me, unless I'm missing something.
S
wizer":1wcbcp1p said:You've lost me there, to the front of what?
Tusses":a1vhjqzf said:ah - the sliding table - never had one, so I will agree, the switch seems better on the right. maybe wire in a foot switch in series ?
Steve Maskery":1cxbo2l2 said:Dom
Thanks for the pics, I see your point now.
However...
Having the switch in the right means that, if you are standing to the left (as you should be) you have to reach across the saw to switch off. You are holding one piece of wood past the blade, you have another unsupported that you have just cut, and you have to lean across the line of the blade. Not good.
I'd prefer to get the blade going first, then get your board in place, then you can switch off easily at the end without leaning anywhere.
I guess it's a compromise between different risks.
S
Steve Maskery":zf66qde9 said:Yes, I think a foot switch wold be the best option in that case, too.
I don't have a sliding table, nor space for one so it's not my problem!
S
Grinding One":lce3zewr said:How is that going to fit in the garage??
p111dom":3vyaqf5a said:Just out of curiosity though Steve, assuming you're right handed when you're ripping do you stand to the left or the right of the blade?
Thats ok just wanted to check I wasn`t doing something different to everyone else.Steve Maskery":3dfwpii3 said:p111dom":3dfwpii3 said:Just out of curiosity though Steve, assuming you're right handed when you're ripping do you stand to the left or the right of the blade?
I stand to the left. Yes, my right arm isto the right of the blade, but the fence is on the right, and if were to staqnd to the right and use my left hand, I wouldn't be able to see so well. It's another compromise, isn't it?
When using my Ultimate Tablesaw Tenon Jig, however, the jig is on the right and so am I.
S
