RogerS
ByronBlack":2fv6jzyb said:Jake = 2.5mm seems to ring a bell, mostly probably right. Tomorrow I think i'll post up some pics just to be on the safe side.
BB - just don't get worried if the lights dim on start-up.
Roger Sinden":3rkv0mzi said:ByronBlack":3rkv0mzi said:Jake = 2.5mm seems to ring a bell, mostly probably right. Tomorrow I think i'll post up some pics just to be on the safe side.
Jake":1uct7lol said:If the SWA is thicker than 2.5mm2 (conductor size), then it can almost certainly run off a bigger MCB than 20A,
ByronBlack":1ftrdfgs said:fella's, you need to treat my like a small child when it comes to electrics
Jake":b7g2z8mu said:ByronBlack":b7g2z8mu said:fella's, you need to treat my like a small child when it comes to electrics
Don't put your fingers in the sockets, you silly boy.
Jake":rfi3n1oh said:The number of wires in (all but one of) the sockets doesn't tell you whether it is a ring (i.e. a loop where the wire comes from the CU, goes through each socket, and then back to the CU) or a radial wired sequentially (i.e. the wire comes from the CU, goes through each socket, but just stops at the last socket instead of going back to the CU). The sockets on a radial circuit can be wired in exactly the same way as in a ring (i.e. with a wire in, and a wire out), except that at the end of the chain, there will not be a wire out back to the CU. So most sockets will look exactly the same either way the circuit is wired - apart from the last one in the chain.
Jake":rfi3n1oh said:Secondly, there is no reason why your socket circuit cannot be a ring circuit, from the workshop CU, while the main feed from house CU to your workshop CU is a radial (one wire) - in fact, that is the norm and the right way to do it.
It is the main supply from your house CU to the workshop CU which has the 20A MCB on it, and it is that circuit which is the limiting factor. If the 20A MCB is there because it needs to be there to protect the armoured cable to the shed, the proper way to do it is to see if it does serve your needs, and if not, replace the armoured cable with a bigger (single) cable.
Given the expense, let's hope the 20A circuit will be enough (as, in all probability, it will be).
Turn the fan heaters off while you are sawing!
