Use something like 50 or 70mm and the tressles with 4 by 2's and you have a workbench, buy one of these Pop Up Gazebos Archives and you can now carry on working outdoors even if it rains.
Yes, including the dust from the Kingspan ... yet more microplastic particles ...chuck a sacrificial sheet of Kingspan or similar on top of your cutting table and let your saw cut a few millimetres into it, it supports whatever you are cutting and improves dust collection
the answer is that you have the wrong tool for the job.Calling all table saw fans - I need some teaching, please.
I got a 2nd hand table saw to:
* make cutting sheet material quicker
* get super clean cuts that don't need further finishing
* cut to final dimensions on first pass
* achieve dead-square (or precisely angled) components such as cabinet sides & doors with ease.
I mostly use 8x4 sheets of mdf, veneered mdf or ply.
It is very true that it is possible to make a saw guide, I have 2 I made 15 or so years ago, if they haven’t been recycled as fire wood, It is a very poor substitute for even the worst track, it doesn’t hold the saw, it must always be clamped (unlike a decent track, mine often don’t need to be clamped), it can’t be extended, it is always higher friction than a track.You can make your own track very simply with a piece of flat sheet material a bit wider than your saw, that has glued/screwed to it a length of straight wood to hold the saw against. Cut along the length of the sheet and you have track which can be aligned to your cut marks.
I think you mean Peter Millard? Would second that. Peter has some excellent content out there on YouTube and other platforms.Peter miller , London craftsman have quite a few videos around MFT on YouTube
Could also use a centipede type trestle and insulation board
Hello,Calling all table saw fans - I need some teaching, please.
I used to use a straight edge and ciruclar saw, then I upgraded to a plunge/track saw. But I'm tired of sorting out support under the workpiece, repeating measurements even for identical components, and moving the track half way through the cut particularly on the 8' dimension. I always ended up with teeth marks or burnbecause I found it difficult to keep a super-steady pace and pressure on long pieces.
But after doing my first test cut on the table saw yesterday, I quickly found 3 big questions:
1. Are full sheets just too unweildy for a table saw - so do you have to cut them down first e.g. with the circular saw?
2. How do you handle large pieces (e.g. 2000x700 for the side of a wardrobe) without the long edge wandering away from the fence even by a mm or two for a second?
3. My fence can be set a maximum of about 200mm from the blade - so what's the workflow for cutting that 2000x700 piece. Do I have to cut to rough dimensions with the track saw, say 2010x710, and then set the table saw fence 5mm from the blade and cut the piece to final size?
I want to end up with great cuts, but I want to do it as efficiently as possible. Advice much appreciated.
What you need are a couple of stands to support the full sheets. They have rollers on the top so that you can push the sheets through the blade.
