Inspector
Nyuck, Nyuck, Nyuck!
Barbara you are to be commended for talking about your mishap to warn others and I hope you the best of recovery outcomes.
While some of the comments here lean towards chastisement they are made with the best of intentions and they shouldn't put you off.
The reason you will never see a retrofit SawStop mechanism for other saws is that the entire assembly under the table is different to any past saw. Impossible to make them for all makes and types. I believe our 60 hertz verses your 50 hertz power is the reason SawStops have not been imported in the past or perhaps your market wouldn't be big enough.
The parent company of Festool has bought the SawStop company and Festool has been playing with some job site saws with the braking mechanism in them. Exact same brake mechanism as my saw actually. I don't know if they hit the market in your neck of the woods but they certainly won't be in the same class as your 12" bladed saw. Some of the original patents are running out soon but there were quite a few filed after for other aspects that may hold competitors from following suit for some years to come. There are a few of the expensive slider type manufacturers with braking mechanisms but as expected are out of the hobby woodworking fraternity.
I have had my SawStop for almost 15 years at least and wouldn't consider trading it for anything else. I work with it exactly as if it didn't have the blade brake and if if it never activates it has still been money well spent. I suggest you consider immigrating here it you want one.
