Hmmm, this video (which I linked to a few pages back, but obviously didn't take in properly) uses a thin paste coat over the glass coat before the hot coat:
https://www.youtube.com/watch?v=JKnbOpC_mic
So in theory, I've just done a thick paste coat and it still needs a hot/ gloss coat. But the question is, does it need it given that my paste coat isn't 'thin' and is glossy?!
Do you think the paste coat is just to give a better finish, so the final coat goes on to a completely smooth surface as opposed to the texture of the glass weave? The finish I have now looks pretty good (overlooking the bubbles - the weave can't be felt when I run my hand across it) and sanding and polishing would make it a better finish again.
And yes, I read that Tn - UV protection (it'll be stored inside when not in use, so probably not such an issue - especially given the limited direct sunlight here in South Wales(!), but also coz it looks good.
Can't believe I've not noticed this process, I must've watched that video 4 times and not spotted the paste coat, so bleedin obvious!
Edit - I found this:
https://greenlightsurfsupply.com/pages/ ... ide-page-4
Useful on the sanding and polishing stage, and says the following:
'Gloss coats are essentially a second hot coat that is fine sanded, compounded, and polished to a shine. Typically, gloss coats are found on longboards and retro-style boards, where weight isn’t a factor. Adding a gloss coat increases the weight of your board, so typically high-performance shortboards skip a gloss coat and are considered done after fine sanding the hot coat to 400 grit or so.' (Terms are used differently on different sites - what's elsewhere the paste coat seems here to be called the hot coat.)
This isn't a high performance short board by any means, but I'm confident there's a good amount of resin on there already for strength, so we'll get on with polishing.
Novocaine - they refer to surfboard polish, which I don't have - can you remember what you used for that final stage? Are there any more readily available polishes for resin?
