The weather gets bad, but the swell gets better - we've got the remnants of Dorian arriving the end of the week!
Ok, last questions (we all hope), if I may.
What kind of router bit do I need to rout for the fin box? I have use of a 1/4" plunge router, all (3 of) my bits just cut edges - it needs to plunge then cut along. And what diameter bit can I go for? I was planning to do 5mm depth passes, working to the depth of the box (some will be cut off the height of the box after fitting) and then a little depth for resin.
And finally, how much gap do you think I need for the resin under and around the box, leash plug and vent?
Thanks.
