Staining 'oak' filler
johnbb99
UKW Supporter
30 May 2018
Lampeter
I've been re-using some previously used oak (another item of furniture) and it has some nail holes, etc to be filled.
Ive bought (at surprising cost) two tubs of filler labelled 'Oak', but they both are too light. Even for my light oak.
You can see the filler is almost white. Beech benchtop, mirka sanding sheet and cork for colour reference.
What would anyone who has been in this situation use to darken the filler? I don't expect it to disappear - this isn't my expectation or requirement, but I would like it to colour and shade match.
(And how come these two big names have got it so wrong? I doubt any oak exists that's significantly paler than what I'm working with. )
Yours looks like it’s sun bleached. Do you have enough off cuts to make some pegs to fill the nail holes.
I would not use filler, I cut pegs/dowels and lined up the grain to plug nail holes in recycled wood.
Maybe the camera is lying - it's why I included other familiar objects, but this is a fresh surface that has never seen the sun. It is sanded, however.
Thanks for the idea of cutting in matching bits. Possible, but there are very many holes, mostly 1-2mm.
I've tried mixing some of the sawdust from this wood with a very little PVA, but that comes out too dark, even when dry!
Might very strong (UK) tea stain the filler effectively?
I would be cautious trying to get a match at this stage on bare wood. If it is going to be finished then the finish will alter the colour, almost invariably making it darker. Better IMO to put a bit of finish on so you establish the colour, then fill and tint to match.
But isn't the finish likely to darken the filler as much as the oak?
I've been struggling with this problem for a couple of years and still finding it just as difficult. I have found that finishes will colour the (wood) oak much differently to the filler and so have found that finish then fill and tint works better for me. The best hide is a set of paints and a model making size paint brush, a big lens, light and time.
I have only ever used the Everbuild filler, very little on each piece made but sometimes it is needed. Nearly always on Oak and can’t say I’ve really had a problem. I think it blends in much better with a finish on top. Sometimes on darker Oak I have mixed in a little of the Mahogany one they make with the light Oak one to colour it a bit.
I would suggest you dab a bit of the finish just on that small area and see how it looks.
Ian
I carry 3 tubs of the Everbuild filler on the van.Light oak, Oak and Mahogany incase of pin holes etc and mix them in various ratios to suit. You want to be looking for it to blend in when it is finished,not a match for the bare timber as has been said.
I use different mixes/ratios even on the same piece of timber to blend it in.
I would also go with the filler sticks. The wax will not change colour when the finish is applied. Otherwise, fill some holes in a matching scrap piece and paint the filler with different shades of acrylic paint then apply your chosen finish remembering each 'mix' for each shade. Once the finish has cured you will see which one matches the surrounding surface. You can see why I go with wax filler sticks.
